RFM69 module w/Raspberry Pi on Win IoT?
- jdsmith99
Any guidance on connecting/operating an RFM69 radio module to a Rasp Pi 3 board using Adafruit's (awesome) WinIoT Core drivers library? Is it doable?
Re: RFM69 module w/Raspberry Pi on Win IoT?
I'm afraid we've never tried that combination. Maybe someone from the community will have suggestions.
- jdsmith99
Thanks, Mike.
I'll give it a shot (admittedly, I have no idea what I'm doing!). We run a lot of IoT projects that use a sort of hub-and-spoke model. The spokes are Feather-equipped sensors (light, temp, humidity, sound, motion, contact, etc.), and the hub is something like an ESP8266 board...something with a WiFi radio. The sensors txmit to the hub via RFM69 radios. The sensor setups are great because the Feather + RFM69 boards are way low-power/super battery-friendly, and the radio means we can put the sensor pretty much anywhere we want. The hub isn't bad, but it would be nice to use a more powerful board for the hub so we can do things like multi-thread,connect even more sensors, connect to a monitor to see what's happening in the web of sensors, etc.
- jdsmith99
I have a working RFM69 library for Win 10 IoT Core. I tested it with an Adafruit RFM breakout board (https://www.adafruit.com/products/3070), and it's working well. It's using the .NET SPI/GPIO classes to communicate with the hardware, so no need for additional libs. Needs a ton of cleanup and testing, but I'll post to github when I get a chance.
Curious if other people are interested in the library.
- terrence7
I am totally interested in your library. Is it working? Please post it.
Thank you.
Thank you.
- johndcrumpton
I'm also interested in the Windows IOT libs for RFM69
- ejulson
I'm interested in the WinIOT RFM69 lib. Please share when you get it ready.
TIA...
TIA...
