Will The Powerboost 1000C safely charging with a 2amp psu?
- Gameboy_Geek
Hi, I was planning on building a PiGRRL2.0 and i'm a little confused about what it says on the Powerboost 1000C page and just wanted something clarified. I have a spare official 5v 2.0 amp Raspberry Pi powersupply, can i safely use this to charge the powerboost (or i suppose the battery through the powerboost) also i've heard the powerboost 1000C can get a littlee hot will that cause problems for the pigrrl?
Re: Will The Powerboost 1000C safely charging with a 2amp ps
That power supply should work. The PowerBoost charger section will draw only the current it needs.
Heating issues with the PowerBoost are generally on the boost end. High current loads make the boost circuit work extra hard. And that generates a lot of waste heat.
- Gameboy_Geek
Thank you very much so it the pigrrl 2.0 should cause the boost to overheat? but still thanks for telling me, i was worried about breaking the project once I've made it because its a fairly significant investment so breaking it would be less than spectacular.adafruit_support_bill wrote:That power supply should work. The PowerBoost charger section will draw only the current i needs.
The PowerBoost 1000C should handle the PiGRRL by itself. But can get overloaded if you start to attach other things to it. Audio amplifiers in particular are power hungry and can result in overloading the PowerBoost.
- Gameboy_Geek
Thankyou very much, yeah im not adding anything extra but thankyou.adafruit_support_bill wrote:The PowerBoost 1000C should handle the PiGRRL by itself. But can get overloaded if you start to attach other things to it. Audio amplifiers in particular are power hungry and can result in overloading the PowerBoost.
