Here is a photo of the circuit. The pins connections are
feather pin 12 --> Fx board Tx
feather pin 11 --> Fx board Rx
feather pin 20 --> Fx board rst
Menu driven control of a sound board over UART.
Commands for playing by # or by name (full 11-char name)
Hard reset and List files (when not playing audio)
Vol + and - (only when not playing audio)
Pause, unpause, quit playing (when playing audio)
Current play time, and bytes remaining & total bytes (when playing audio)
Connect UG to ground to have the sound board boot into UART mode
#include <SoftwareSerial.h>
#include "Adafruit_Soundboard.h"
// Choose any two pins that can be used with SoftwareSerial to RX & TX
#define SFX_TX 12
#define SFX_RX 11
// Connect to the RST pin on the Sound Board
#define SFX_RST 20
// You can also monitor the ACT pin for when audio is playing!
// we'll be using software serial
SoftwareSerial ss = SoftwareSerial(SFX_TX, SFX_RX);
// pass the software serial to Adafruit_soundboard, the second
// argument is the debug port (not used really) and the third
// arg is the reset pin
Adafruit_Soundboard sfx = Adafruit_Soundboard(&ss, NULL, SFX_RST);
// can also try hardware serial with
// Adafruit_Soundboard sfx = Adafruit_Soundboard(&Serial1, NULL, SFX_RST);
Serial.begin(115200);
Serial.println("Adafruit Sound Board!");
// softwareserial at 9600 baud
ss.begin(9600);
// can also do Serial1.begin(9600)
if (!sfx.reset()) {
Serial.println("Not found");
while (1);
Serial.println("SFX board found");
flushInput();
Serial.println(F("What would you like to do?"));
Serial.println(F("[r] - reset"));
Serial.println(F("[+] - Vol +"));
Serial.println(F("[-] - Vol -"));
Serial.println(F("[L] - List files"));
Serial.println(F("[P] - play by file name"));
Serial.println(F("[#] - play by file number"));
Serial.println(F("[=] - pause playing"));
Serial.println(F("[>] - unpause playing"));
Serial.println(F("[q] - stop playing"));
Serial.println(F("[t] - playtime status"));
Serial.println(F("> "));
while (!Serial.available());
char cmd = Serial.read();
flushInput();
switch (cmd) {
case 'r': {
if (!sfx.reset()) {
Serial.println("Reset failed");
break;
case 'L': {
uint8_t files = sfx.listFiles();
Serial.println("File Listing");
Serial.println("========================");
Serial.println();
Serial.print("Found "); Serial.print(files); Serial.println(" Files");
for (uint8_t f=0; f<files; f++) {
Serial.print(f);
Serial.print("\tname: "); Serial.print(sfx.fileName(f));
Serial.print("\tsize: "); Serial.println(sfx.fileSize(f));
break;
case '#': {
Serial.print("Enter track #");
uint8_t n = readnumber();
Serial.print("\nPlaying track #"); Serial.println(n);
if (! sfx.playTrack(n) ) {
Serial.println("Failed to play track?");
break;
case 'P': {
Serial.print("Enter track name (full 12 character name!) >");
char name[20];
readline(name, 20);
Serial.print("\nPlaying track \""); Serial.print(name); Serial.print("\"");
if (! sfx.playTrack(name) ) {
break;
case '+': {
Serial.println("Vol up...");
uint16_t v;
if (! (v = sfx.volUp()) ) {
Serial.println("Failed to adjust");
} else {
Serial.print("Volume: "); Serial.println(v);
break;
case '-': {
Serial.println("Vol down...");
uint16_t v;
if (! (v=sfx.volDown()) ) {
} else {
Serial.println(v);
break;
case '=': {
Serial.println("Pausing...");
if (! sfx.pause() ) Serial.println("Failed to pause");
break;
case '>': {
Serial.println("Unpausing...");
if (! sfx.unpause() ) Serial.println("Failed to unpause");
break;
case 'q': {
Serial.println("Stopping...");
if (! sfx.stop() ) Serial.println("Failed to stop");
break;
case 't': {
Serial.print("Track time: ");
uint32_t current, total;
if (! sfx.trackTime(¤t, &total) ) Serial.println("Failed to query");
Serial.print(current); Serial.println(" seconds");
break;
case 's': {
Serial.print("Track size (bytes remaining/total): ");
uint32_t remain, total;
if (! sfx.trackSize(&remain, &total) )
Serial.print(remain); Serial.print("/"); Serial.println(total);
break;
/************************ MENU HELPERS ***************************/
void flushInput() {
// Read all available serial input to flush pending data.
uint16_t timeoutloop = 0;
while (timeoutloop++ < 40) {
while(ss.available()) {
ss.read();
timeoutloop = 0; // If char was received reset the timer
delay(1);
char readBlocking() {
return Serial.read();
uint16_t readnumber() {
uint16_t x = 0;
char c;
while (! isdigit(c = readBlocking())) {
//Serial.print(c);
Serial.print(c);
x = c - '0';
while (isdigit(c = readBlocking())) {
Serial.print(c);
x *= 10;
x += c - '0';
return x;
uint8_t readline(char *buff, uint8_t maxbuff) {
uint16_t buffidx = 0;
while (true) {
if (buffidx > maxbuff) {
break;
if (Serial.available()) {
char c = Serial.read();
//Serial.print(c, HEX); Serial.print("#"); Serial.println(c);
if (c == '\r') continue;
if (c == 0xA) {
if (buffidx == 0) { // the first 0x0A is ignored
continue;
buff[buffidx] = 0; // null term
return buffidx;
buff[buffidx] = c;
buffidx++;
return buffidx;
