A Motion-Activated Solder Fume Extractor with Light
by HarpDude on Fri Jul 21, 2017 2:48 am
There are a few fundamental devices that beginning makers design: clocks and solder fume extractors. After many, many years of making, I thought it was about time to finally build the latter. Requirements: 1) small, no larger than 3x5x3 inches, 2) low-profile, 3) rechargeable battery powered with 1-2 hour run time, 4) activated carbon filter, 5) low noise, 6) USB port for gooseneck work lamp, 7) at least one colorful LED status indicator. To meet #3, I added a low-power motion detector to watch the parked soldering iron, only turning on the fan for a predefined period when the iron is removed. I also adjusted the enclosure design so that the motion detector would work with right-handed and left-handed solderers. Here's the wiring diagram and parts list.
Motion-Activated Solder Fume Extractor Wiring Diagram/Parts List
Fume Extractor_bba 800p.jpg (157.37 KiB) Viewed 399 times
A video of the final test of the extractor: https://youtu.be/btGl2i0DtRc
The guts.
Fume Extract int lores 1000p.jpg (348.92 KiB) Viewed 399 times
The requisite glamour shot (with USB lamp).
DSC04078a 800p.jpg (166.78 KiB) Viewed 399 times
Using a 500mAh battery, the unit runs for about 4 hours between charges when used nominally (~20% fan duty cycle, 100% medium-brightness lamp duty cycle). During the motion detection mode test (power on, blue LED indicator glowing, USB lamp off, fan not running), the extractor patiently waited for over 28 hours for me to start soldering -- I terminated the standby test out of boredom.
The PowerBoost 500C was perfect for this design. Thanks Adafruit!
HarpDude
Re: A Motion-Activated Solder Fume Extractor with Light
by adafruit_support_mike on Fri Jul 21, 2017 3:08 am
Nice build.. thanks for posting it!
