I used the code from https://github.com/adafruit/Adafruit_Python_BME280 and built a RPi Zero-based sensor for my shed. Every 5 minutes, I collected the each of the data points (temp, pressure, humidity) and posted it to adafruit io. This ran fine from 6/17 until 8/30. (Roughly I collected 21600 readings.) However, on Wednesday I started to notice this error:
Sep 03 16:52:45 zero monitor.py[875]: File "/usr/local/lib/python2.7/dist-packages/Adafruit_BME280.py", line 136, in __init__
Sep 03 16:52:45 zero monitor.py[875]: self._load_calibration()
Sep 03 16:52:45 zero monitor.py[875]: File "/usr/local/lib/python2.7/dist-packages/Adafruit_BME280.py", line 147, in _load_calibration
Sep 03 16:52:45 zero monitor.py[875]: self.dig_T1 = self._device.readU16LE(BME280_REGISTER_DIG_T1)
Sep 03 16:52:45 zero monitor.py[875]: File "build/bdist.linux-armv6l/egg/Adafruit_GPIO/I2C.py", line 185, in readU16LE
Sep 03 16:52:45 zero monitor.py[875]: File "build/bdist.linux-armv6l/egg/Adafruit_GPIO/I2C.py", line 164, in readU16
Sep 03 16:52:45 zero monitor.py[875]: File "build/bdist.linux-armv6l/egg/Adafruit_PureIO/smbus.py", line 173, in read_word_data
Sep 03 16:52:45 zero monitor.py[875]: IOError: [Errno 121] Remote I/O error
#!/usr/bin/env python
from Adafruit_IO import Client
from Adafruit_BME280 import *
import logging
logging.basicConfig(level=logging.INFO)
logger = logging.getLogger(__name__)
aio = Client('<my key>')
sensor = BME280(t_mode=BME280_OSAMPLE_8, p_mode=BME280_OSAMPLE_8, h_mode=BME280_OSAMPLE_8)
degrees = sensor.read_temperature()
pascals = sensor.read_pressure()
hectopascals = pascals / 100
humidity = sensor.read_humidity()
logger.info('Temp = {0:0.2f} deg C'.format(degrees))
logger.info('Pressure = {0:0.2f} hPa'.format(hectopascals))
logger.info('Humidity = {0:0.2f} %'.format(humidity))
try:
aio.send("Temperature", degrees)
aio.send("Pressure", hectopascals)
aio.send("Humidity", humidity)
except:
logger.error("Cannot connect to Adafruit.io")
Sep 03 17:05:50 zero monitor.py[763]: INFO:__main__:Temp = 36.64 deg C
Sep 03 17:05:50 zero monitor.py[763]: INFO:__main__:Pressure = 1013.82 hPa
Sep 03 17:05:50 zero monitor.py[763]: INFO:__main__:Humidity = 38.61 %
