Connection to PC
Connection to PC
by Cagott5 on Fri Oct 20, 2017 11:29 am
Would like to connect the Adafruit Ultimate GPS Breakout - 66 channel w/10 Hz updates - Version 3 board to a Windows PC via USB. What do we need?
FTDI friend? Anything else, USB cable.
Cagott5
Re: Connection to PC
by franklin97355 on Fri Oct 20, 2017 2:07 pm
An FTDI Friend and appropriate cable would work
franklin97355
by Cagott5 on Wed Oct 25, 2017 11:12 am
Purchased the FTDI friend and the Ultimate GPS MT3339 V3 connecting wire.
Windows 10 did not ask to install driver and displays a com port 13 in device manage when I plug it in.
in Control panel I Set com port speed to 9600 and it states Information
made sure Set RTS in was unchecked
GPS flashes fast at cold boot then goes to single red flash every 15 seconds.. assume we have link
downloaded the MT3339 PC Tool v1.3 unziped and run.
select com port 13 and set to 9600. When I click open the FTDI Friend Flickering red light is on. but No Data.
FTDI <=> GPS
GND GND
VCC VIN
TX TX
RX RX
What am I doing wrong?
Cagott5
by Cagott5 on Wed Oct 25, 2017 11:48 am
Oops never mind.... TX to RX and RX to TX
Cagott5
by EngrHasnainMoavia on Fri Mar 01, 2019 6:06 pm
Hello!
After the correction in the respective wiring, did it work correctly then?
Can you please provide a URL of the MT3339 PC Tool v1.3 software or any other latest software to access the data on PC?
EngrHasnainMoavia
