BNO055 freeze after few seconds
by atlasvencent on Sun Oct 29, 2017 2:18 pm
Hi, I bought a few new BNO055 from adafruit recently and soldered it to feather M0 board. I wired it exactly the way described in the toturial, and I used the sensorapi example from the adafruit library.. The sensor works fine in the beginning. But more often than not, the sensor would stop responding after a few seconds, and the there would be no data sent to the serial monitor anymore. This happens all the time no matter which example I use. Is there any way to fix this?
Here's the code from sensor api:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BNO055.h>
#include <utility/imumaths.h>
/* This driver uses the Adafruit unified sensor library (Adafruit_Sensor),
   which provides a common 'type' for sensor data and some helper functions.
s
   To use this driver you will also need to download the Adafruit_Sensor
   library and include it in your libraries folder.
   You should also assign a unique ID to this sensor for use with
   the Adafruit Sensor API so that you can identify this particular
   sensor in any data logs, etc.  To assign a unique ID, simply
   provide an appropriate value in the constructor below (12345
   is used by default in this example).
   Connections
   Connect SCL to analog 5
   Connect SDA to analog 4
   Connect VDD to 3-5V DC
   Connect GROUND to common ground
   History
   2015/MAR/03  - First release (KTOWN)
   2015/AUG/27  - Added calibration and system status helpers
/* Set the delay between fresh samples */
#define BNO055_SAMPLERATE_DELAY_MS (100)
Adafruit_BNO055 bno = Adafruit_BNO055(55);
    Displays some basic information on this sensor from the unified
    sensor API sensor_t type (see Adafruit_Sensor for more information)
void displaySensorDetails(void)
  sensor_t sensor;
  bno.getSensor(&sensor);
  Serial.println("------------------------------------");
  Serial.print  ("Sensor:       "); Serial.println(sensor.name);
  Serial.print  ("Driver Ver:   "); Serial.println(sensor.version);
  Serial.print  ("Unique ID:    "); Serial.println(sensor.sensor_id);
  Serial.print  ("Max Value:    "); Serial.print(sensor.max_value); Serial.println(" xxx");
  Serial.print  ("Min Value:    "); Serial.print(sensor.min_value); Serial.println(" xxx");
  Serial.print  ("Resolution:   "); Serial.print(sensor.resolution); Serial.println(" xxx");
  Serial.println("");
  delay(500);
    Display some basic info about the sensor status
void displaySensorStatus(void)
  /* Get the system status values (mostly for debugging purposes) */
  uint8_t system_status, self_test_results, system_error;
  system_status = self_test_results = system_error = 0;
  bno.getSystemStatus(&system_status, &self_test_results, &system_error);
  /* Display the results in the Serial Monitor */
  Serial.println("");
  Serial.print("System Status: 0x");
  Serial.println(system_status, HEX);
  Serial.print("Self Test:     0x");
  Serial.println(self_test_results, HEX);
  Serial.print("System Error:  0x");
  Serial.println(system_error, HEX);
  Serial.println("");
  delay(500);
    Display sensor calibration status
void displayCalStatus(void)
  /* Get the four calibration values (0..3) */
  /* Any sensor data reporting 0 should be ignored, */
  /* 3 means 'fully calibrated" */
  uint8_t system, gyro, accel, mag;
  system = gyro = accel = mag = 0;
  bno.getCalibration(&system, &gyro, &accel, &mag);
  /* The data should be ignored until the system calibration is > 0 */
  Serial.print("\t");
  if (!system)
    Serial.print("! ");
  /* Display the individual values */
  Serial.print("Sys:");
  Serial.print(system, DEC);
  Serial.print(" G:");
  Serial.print(gyro, DEC);
  Serial.print(" A:");
  Serial.print(accel, DEC);
  Serial.print(" M:");
  Serial.print(mag, DEC);
    Arduino setup function (automatically called at startup)
void setup(void)
  Serial.begin(9600);
  Serial.println("Orientation Sensor Test"); Serial.println("");
  /* Initialise the sensor */
  if(!bno.begin())
    /* There was a problem detecting the BNO055 ... check your connections */
    Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
    while(1);
  delay(1000);
  /* Display some basic information on this sensor */
  displaySensorDetails();
  /* Optional: Display current status */
  displaySensorStatus();
  bno.setExtCrystalUse(true);
    Arduino loop function, called once 'setup' is complete (your own code
    should go here)
void loop(void)
  /* Get a new sensor event */
  sensors_event_t event;
  bno.getEvent(&event);
  /* Display the floating point data */
  Serial.print("X: ");
  Serial.print(event.orientation.x, 4);
  Serial.print("\tY: ");
  Serial.print(event.orientation.y, 4);
  Serial.print("\tZ: ");
  Serial.print(event.orientation.z, 4);
  /* Optional: Display calibration status */
  displayCalStatus();
  /* Optional: Display sensor status (debug only) */
  //displaySensorStatus();
  /* New line for the next sample */
  Serial.println("");
  /* Wait the specified delay before requesting nex data */
  delay(BNO055_SAMPLERATE_DELAY_MS);
atlasvencent
Re: BNO055 freeze after few seconds
by duckman01 on Mon Oct 30, 2017 4:42 pm
atlasvencent, the only suggestion l can give, which fixed the same problem is in the cabling from the I2C comm's IMU to Arduino board.
Even with short pinned cables l had the IMU lock up.
I now have up to 8M of cat 5 cable and have not had any further Lock Up.
Blue/Blue white = 5 or 3V +
Orange = SDA
Brown white = SDL
Orange white + Brown = not connected/cut off short at IMU end, connect other end as below
all others = 5 or 3V -
duckman01
by gammaburst on Wed Nov 01, 2017 2:30 am
My BNO055 was very intermittent when connected to a Feather M0 WiFi. I fixed it by simply adding unequal I2C pullup resistors: 2.2K on SDA, and 4.7K on SCL. (It helps overcome an unfortunate tight timing situation caused by the BNO055.) Maybe that will work for you too.
gammaburst
by bretthoward on Sat Jan 20, 2018 6:41 pm
I'm having a similar issue where it runs for quite a while (like 20+ minutes) and then all the sudden poof it crashes the whole thing and with a few print statements I've narrowed the problem down to the area where I read from the BNO055. In checking my pullups I'm at about 2400 ohms on SCL and SDA without extra pullup resistors because on the I2C bus I have a Alpha numeric display, An APDS9960 optical sensor breakout, and a BMP280 Barometric pressure sensor on the bus with it... I've even added the compTimer logic in there to slow down how often I read from it which seems to make things more stable but not rock solid like I need...
cout << "About to check heel " << millis() << endl;
  //Determine if we're over heeling
  if(millis() > compTimer + 100) {
    bno.getEvent(&compEvent);
    curHeelAngle = abs(compEvent.orientation.y);
    compTimer = millis();
  cout << "Got the event from the compass" << endl;
bretthoward
