micro SD Cards, NOT BLANK
by plc_gremlin on Thu Nov 23, 2017 1:31 am
Dear Adafruit,
I have a project where I am starting to use the "Blank" 4GB micro SD card's you sell.
I use them with Teensy 3.5 and will likely be using ALOT of them.
They are unfortunately not Blank..
You guys are using a MAC(I assume) when you format them and it is leaving little MAC droppings all over the place.
About 93 hidden Files and Folders.
It would be awesome if you could figure out a way to send them out completely Blank so we don't have to reload them onto a Windows box and remove all the files before we can use with T3.5's. I don;t think that the Teensy 3.5 can remove the files itslef because it only reports 8.3 filenames and you need the filename to be able to do a SD.remove("filename");..
Thanks, you guys(and gals) are great!
Here is a Serial.print listing from the Arduino Example SD Card program ListFiles.
Initializing SD card...initialization done.
~1.TRA      4096
TRASHE~1/
SPOTLI~1/
   STORE-V2/
      958858~1/
         PSID.DB      8192
         TM~1.SNO      0
         TM~1.LIO      0
         LIO~1.CRE      0
         TMP.CAB      0
         CA~1.CRE      0
         INDEXS~1      28
         ~1.IND      4096
         ~~2.IND      16
         ~~~3.IND      3277
         ~~~~4.IND      4096
         ~~~~~5.IND      384
         ~~~~~~34.IND      4096
         ~~~~~~37.IND      384
         ~~~~~~40.IND      2056
         ~~~~~~43.IND      8
         ~~~~~~46.IND      832
         ~~~~~~48.IND      13
         ~1.DIR      65536
         LIVE~~~4.IND      276
         LIVE~~2.IND      24
         LIVE~~~3.IND      3277
         LIVE~~~5.IND      4
         LIVE~~66.IND      2056
         LIVE~~69.IND      8
         LIVE~~73.IND      66304
         LIVE~1.SHA      4096
         LIVE~1.DIR      65536
         LIVE0D~1.SHA      1088
         STORE.DB      118784
         STOR~1.DB      118784
         REVERS~1      65536
         TMPSPO~1.STA      4096
         JOURNA~1.1      0
         STORE_~1      4
         JOURNA~1.COR/
         JOURNA~1.LIV/
         JOURNA~2.LIV/
         JOURNA~3.LIV/
         JOURNA~4.LIV/
         JOURNA~1.ASS/
         JOURNA~2.ASS/
         JOURNA~1.HEA/
         JOURNA~1.MIG/
         JOURNA~2.MIG/
         JOURNA~1      0
         JOURNA~1.SCA/
            RETIRE.4      0
         PERMST~1      553
         SHUTDO~1      4
         REVERS~1.SHA      3136
         ~1.SHA      4096
         JOURNA~1.REP/
         CA~1.MOD      0
         LIVE~162.IND      4096
         LIVE~165.IND      32768
         0DIREC~1.SHA      1088
         ~~~~~173.SHA      2
         LIVE~1.IND      4096
         LIVE~201.SHA      3
         STOR~1.UPD      3
         REVERS~1.UPD      1
         LIVE~209.IND      3277
         TMPSPO~1.LOC      1968
         LIVE~215.IND      4096
         LIVE~218.IND      8192
         LIVE~221.IND      4096
         LIVE~224.IND      8192
         LIVE~227.IND      8224
         LIVE~230.IND      1024
         LIVE~234.IND      65536
         LIVE~237.IND      0
         LIVE~~2.DIR      65536
         LIVE~243.SHA      4096
         LIVE~246.SHA      0
         LIVE~249.SHA      0
         LIVE~253.SHA      65536
         LIVE~256.SHA      8
         LIVE~260.SHA      2056
         LIVE1D~1.SHA      1088
         LIVE~268.SHA      1
   STORE-V1/
      VOLUME~1.PLI      348
   VOLUME~1.PLI      4008
FSEVEN~1/
   FSEVEN~1      36
   000000~1      45
   000000~2      72
done!
plc_gremlin
Re: micro SD Cards, NOT BLANK
by plc_gremlin on Thu Nov 23, 2017 1:32 am
Couldn't find the edit button:
I'm talking about these.
https://www.adafruit.com/product/102
plc_gremlin
by adafruit_support_mike on Thu Nov 23, 2017 2:37 am
I'll check with the folks who handle the cards for sale. Thanks for letting us know!
by adafruit2 on Thu Nov 23, 2017 1:57 pm
thats.. very odd. are *all of them* not blank?
adafruit2
Site Admin
by andrhamm on Fri Dec 15, 2017 3:26 pm
I'm also seeing this... it seems Mac is dropping all of these little garbage files on the card immediately after doing a full Overwrite Format with the official SD Card Formatter app... annoying!
andrhamm
by andrhamm on Fri Dec 15, 2017 3:33 pm
You can prevent Spotlight from adding those files in
System Prefs → Spotlight → Privacy
But if they are already on there you have to remove them via Terminal. In my case:
rm -rf .Spotlight-V100/
rm -rf .fseventsd/
andrhamm
by adafruit2 on Fri Dec 15, 2017 5:17 pm
yeah we dont look at the cards before we mail them, plc did you maybe look at the card on a mac before plugging it into a teensy?
adafruit2
Site Admin
by plc_gremlin on Fri Dec 15, 2017 10:56 pm
No, I don't own a Mac.
I opened the package, plugged it into a Teensy 3.5 and noticed all the files.
Then plugged into Windows machine to see what they were. Googled some of the files and found info that andrhamm suggested. They are being added by spotlight on a Mac,
Ok. To answer your first question. I just checked.
2 out of the 10 that I bought did not have the files... this is really strange as I expected they would all be the same. I'm 99.26% confident that I didn't plug a couple in a delete files back when I first noticed this. but... I've been going 99mph on projects so.. maybe???
They have to be being plugged into a Mac somewhere along the line before they arrived at my door.
Have you guys grabbed some out of your stock to see if they have the files? check them on a Windows PC of course.
this is not an earth shattering issue, just one less thing I have to worry about if they arrived blank. Will probably be ordering more soon.
plc_gremlin
by adafruit2 on Sat Dec 16, 2017 3:21 pm
we'll take a look - you're referring to
right?
adafruit2
Site Admin
by plc_gremlin on Sat Dec 16, 2017 3:37 pm
yes.
plc_gremlin
by adafruit2 on Mon Dec 18, 2017 12:53 pm
ok thanks - we checked this out, and found that a few weeks ago we had a QA check on these cards (some we had gotten were corrupted) and we had unwittingly used a Mac to just check that the card comes up as a drive. The good news - if it has those files, we know it's a good card! :) Going forward we will no longer use a Mac. thanks for alerting us!
adafruit2
Site Admin
by plc_gremlin on Mon Dec 18, 2017 8:25 pm
Ok, great.
Thanks for the update.
plc_gremlin
