I bought a KOOKYE Optical Fingerprint Reader Sensor Module Locks All-in-one For Arduino R3 this is the first time I have tried any thing like this as its my college project. I am using a mega 2560, I have contacted the finger scanner to the board like your video in this link https://www.youtube.com/watch?v=1diFaa5OsFg . The scanner flickers green for second then off and there no other lights showing on the scanner. I then down loaded the library and then done the enrolling and then it say no finger scanner found like in the pictures below.
https://i.imgur.com/hA56VGl.png
https://i.imgur.com/y8h6oUG.png
problem with optical finger scanner
- adafruit2
Re: problem with optical finger scanner
hiya did you purchase this from adafruit?
- Matthew2016
Hi no I never but I went and bought one from adafruit and the front lights up green but the computer can not still find the find the finger scanner
- adafruit2
do you have an UNO? if you are using a Mega try to wire it up with Hardware Serial
https://www.arduino.cc/reference/en/lan ... on/serial/
and post a photo of it with the adafruit sensor!
- Matthew2016
Hi I am using a Arduino uno here is some images that may help also so all the help that I cant it would be most appreciated as I am getting close to my college dead line
Firstly the finger scanner:
https://imgur.com/CnpVQWP
https://imgur.com/Zn48J3N
https://imgur.com/6fgH6Vn
https://imgur.com/co9BgDC
Next pictures of uno:
https://imgur.com/GIN2gqw
https://imgur.com/GOWDvtR
Next images of me going through the process of setting code up:
https://imgur.com/VDFEbtM
https://imgur.com/D1BcHAn
Then the next image is where I am having problem where it saying it cant find scanncer:
https://imgur.com/sugO0Hs
- adafruit2
please wire the sensor directly to the uno, and take a well lit photo showing both!
- Matthew2016
hi there think I have nearly got it working as it can be seen in the pictures below but cant get the other light to flash when correct finger is scanned and it can be seen that I am getting good verification. I have used to red LEDs as I was thinking the LEDs was the problem
https://imgur.com/wygAWiP
code verification percentages
https://imgur.com/OartJEG
- adafruit2
yep that looks good!
- Matthew2016
still cant the green led light up . I was also wanting to add a motor to open a door when write finger is scanned a buzzer to be st of if the wrong finger is applied is there any help you can give me thanks
- adafruit2
please run the example codes from the arduino library to start, such as Enrolling or Detecting Fingerprint - then you can add more capability
- Matthew2016
hi there I got a optical finger reader off use's and I was wonder why the enrol cant find the the finger scanner can you please help
- adafruit2
matt, did you order the sensor from adafruit?
