Adafruit I2S MEMS Microphone on raspberry pi 3 error
tmratwork
Post by tmratwork »
the error: CPU DAI 3f203000.i2s not registered
pi@raspberrypi:~ $ dmesg | grep asoc
[ 2.967405] register platform device 'asoc-simple-card': 0
[ 3.392224] asoc-simple-card asoc-simple-card.0: ASoC: CPU DAI 3f203000.i2s not registered - will retry
[ 3.574000] asoc-simple-card asoc-simple-card.0: ASoC: CPU DAI 3f203000.i2s not registered - will retry
[ 3.574468] asoc-simple-card asoc-simple-card.0: ASoC: CPU DAI 3f203000.i2s not registered - will retry
[ 3.650377] asoc-simple-card asoc-simple-card.0: ASoC: CPU DAI 3f203000.i2s not registered - will retry
[ 3.659547] asoc-simple-card asoc-simple-card.0: snd-soc-dummy-dai <-> 3f203000.i2s mapping ok
following the adafruit tutorial at -> https://learn.adafruit.com/adafruit-i2s ... g-and-test
this used to work on an older installation, but cannot get it to work on the rpi with a new installation. other information about the rpi:
pi@raspberrypi:~ $ vcgencmd version
Dec 1 2017 16:16:37
Copyright (c) 2012 Broadcom
version 38ac72569d7fbd7cf75754d9f14c2495416aaee7 (clean) (release)
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.9.67-v7+ #1061 SMP Tue Dec 5 17:17:24 GMT 2017 armv7l GNU/Linux
pi@raspberrypi:~ $ arecord -l
**** List of CAPTURE Hardware Devices ****
card 1: sndrpisimplecar [snd_rpi_simple_card], device 0: simple-card_codec_link snd-soc-dummy-dai-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
tmratwork
Re: Adafruit I2S MEMS Microphone on raspberry pi 3 error
Post by tmratwork »
sovled:
1) after fresh install of rasbian, followed tutorial "Add an I2S mic using device tree & simple-audio-card" at https://www.raspberrypi.org/forums/view ... 4&t=173640
2) moved the positive negative mic connections to top half of breadboard (i thought positive/negative rails spanned entire board, but on my board positive/negative on rows 1-30 are connected, and 31-60 connected... my rpi power was in the top half, mics were connected to rails on the bottom half)
