PowerBoost 1000 Overheating
by thedroidness on Thu Dec 14, 2017 2:44 pm
I am having the same problem with Powerboost 1000 Basic - 5V USB Boost @ 1000mA from 1.8V+ I received. It has been overheating every time its plugged in. I am also using a Lithium Ion Cylindrical Battery - 3.7V 2200mAh and USB/DC/Solar Lithium Ion/Polymer charger with it.
I checked the polarity on the battery and it was good. I tried plugging a USB cable in to see if the energy will flow through, but it doesn't. I have also tried putting a 2.2k ohm resistor on the polymer charger, in hopes that it may have done something, but the powerboost continues to overheat. I think it has got too hot that the wires fell off, but the solder is still kept on. I have also tried wiring a push button to it, in hopes for something, but still overheating.
Please let me know if there is anything else I can try.
thedroidness
Re: PowerBoost 1000 Overheating
by adafruit_support_mike on Sat Dec 16, 2017 5:01 am
With everything disconnected from the PowerBoost, what resistance do you see between the BAT and GND pins?
by thedroidness on Sat Dec 16, 2017 1:00 pm
Hello Mike,
Thanks for reaching out. There is about 1K resistance between BAT and GND.
What should I do next?
thedroidness
by adafruit_support_mike on Tue Dec 19, 2017 4:41 am
That suggests a blown switch in the boost converter.
Just to check, when did you get the PowerBoost?
by thedroidness on Tue Dec 19, 2017 12:37 pm
I ordered the powerboost on Friday 24 November, but didn't receive it until Saturday 2 December.
thedroidness
by adafruit_support_mike on Wed Dec 20, 2017 2:43 am
That's still well within our return/replace period, thank you.
Send a note containing a link to this thread and your order number to support@adafruit.com. The folks there will get you another PowerBoost 1000 Basic.
(#2030)
by thedroidness on Wed Dec 20, 2017 2:16 pm
Thank you for all of your support! I have emailed them and looking forward to hearing from them.
thedroidness
