USB data to FX soundboard
by ivanbusquets on Sat Dec 16, 2017 4:05 am
I have the 16MB Audio FX Sound Board + Amp and am having trouble (like many others, from what I've seen in this forum) to get my Windows 10 computer to see it as a drive.
It didn't work initially with the first cable I tried (even though it was a data USB cable), but DID work with a second one.
Now that I've been testing the soundboard and am ready to use it in a project, I would like to connect it as a drive again, but can't get my computer to see it as a drive again, even using the cable that worked the first time around.
The green LED turns on, but no matter what I do it doesn't seem to want to connect in "data" mode, and defaults to "power" mode instead.
I know it has worked before with this board... Any tips/tricks to making this work again?
ivanbusquets
Re: USB data to FX soundboard
by ivanbusquets on Sun Dec 17, 2017 2:53 am
Hmm, I got it to work again, using the same cable that wasn't working before.
No connections changed in between, so I'm a little bit stumped, but it's working now anyway.
ivanbusquets
by adafruit_support_mike on Tue Dec 19, 2017 4:49 am
Some USB cables work better than others.
USB is a high-speed protocol and the cable is a component, not just a couple of wires stuck in the middle. Different vendors make them differently, and the quality varies.
When in doubt, it's always worth trying another cable.
by shazammagic on Fri Mar 23, 2018 2:56 pm
I was having similar connectivity issues (using an ADA2341, 16mb with no amp), but disconnecting all the inputs solves the problem.
When I leave the input wires intact (they're attached to an Arduino MEGA), both the green and red LEDs are on solid, and the computer doesn't see it as a drive. The entire system is turned off and unplugged when I'm attempting the upload.
Any idea what's going on here? Disconnecting/reconnecting all the input wires every time I need to upload is getting tiring :-) Many thanks!
shazammagic
