Magic Wand Error
Magic Wand Error
by EvanDallas on Thu Feb 15, 2018 3:08 pm
I get this error when downloading the Magic_Wand.ino from this page.
https://learn.adafruit.com/magic-wand/software
<Error>
<Code>AccessDenied</Code>
<Message>Access Denied</Message>
<RequestId>CE669D4607D645F6</RequestId>
<HostId>
Ey39UKxEmBqOqNaDZShIQqsUCCjQSYDT0Tr8Y+emPWRYe4OP+Ba2qR1PPusi8nBSNjtq4/tiMeA=
</HostId>
</Error>
EvanDallas
Re: Magic Wand Error
by EvanDallas on Thu Feb 15, 2018 3:13 pm
But then I get
Arduino: 1.8.5 (Windows 10), Board: "Adafruit Feather 32u4"
C:\Users\Evan\Documents\Arduino\sketch_feb15a\sketch_feb15a.ino: In function 'void setup()':
sketch_feb15a:75: error: 'ConnectSensor' was not declared in this scope
   ConnectSensor();
sketch_feb15a:76: error: 'setupSensor' was not declared in this scope
   setupSensor();
sketch_feb15a:77: error: 'setupNeoPixel' was not declared in this scope
   setupNeoPixel();
sketch_feb15a:92: error: 'waitSFXFinish' was not declared in this scope
     waitSFXFinish();
C:\Users\Evan\Documents\Arduino\sketch_feb15a\sketch_feb15a.ino: In function 'void loop()':
sketch_feb15a:192: error: 'setColor' was not declared in this scope
       setColor(strip.Color(255, 255, 255, 255));
sketch_feb15a:199: error: 'setColor' was not declared in this scope
       setColor(strip.Color(150, 255, 100));;
sketch_feb15a:206: error: 'setColor' was not declared in this scope
       setColor(strip.Color(255, 50, 20));
sketch_feb15a:213: error: 'setColor' was not declared in this scope
       setColor(strip.Color(0, 0, 255, 100));
sketch_feb15a:221: error: 'sfxActive' was not declared in this scope
     if (!sfxActive()) {
sketch_feb15a:223: error: 'setColor' was not declared in this scope
       setColor(strip.Color(0, 0, 0));
Multiple libraries were found for "Wire.h"
 Used: C:\Users\Evan\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.12\libraries\Wire
 Not used: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
exit status 1
EvanDallas
//Written by Alex Alves for Adafruit Industries.
//Adafruit invests time and resources providing this open source code,
//please support Adafruit and open-source hardware by purchasing products
//from Adafruit!
//BSD license, all text above must be included in any redistribution.
#include <SoftwareSerial.h>
#include "Adafruit_Soundboard.h"
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_LSM9DS0.h>
#include <Adafruit_Sensor.h>  // not used in this demo but required!
#define HARDWARETEST 0 // set to 1 to play sound and test neopixles at start up
#define PRINTDATA 0   // prints out sensor data
////////////    SENSOR SETTINGS     ////////////////////
// these settings may have to be changed and calibrated
// orinetation
#define VERTICALVAL 11000  // decrease for more senstive
#define HORIZVAL 6000     //  increase for more senstive
// flick detection
#define FLICKTRIG 17000 // lower = more senstive
// Wrist twist
#define WRISTDIFF 13000 // lower = more senstive
#define WRISTGY  25000 // higher = more senstive
// Sound
// Choose any two pins that can be used with SoftwareSerial to RX & TX
#define SFX_TX 11
#define SFX_RX 10
// Connect to the RST pin on the Sound Board
#define SFX_RST 18
#define SFX_ACT 23
// we'll be using software serial
SoftwareSerial ss = SoftwareSerial(SFX_TX, SFX_RX);
Adafruit_Soundboard sfx = Adafruit_Soundboard(&ss, NULL, SFX_RST);
// NeoPixels
#define PIXELPIN 9
#define NUM_LEDS 7
#define BRIGHTNESS 255 // max 255
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIXELPIN, NEO_GRBW + NEO_KHZ800);
// IMU
Adafruit_LSM9DS0 lsm = Adafruit_LSM9DS0();
enum orientation {
  horiz,
  vertical,
  mid
// Global state variables
bool wristTwist = false;
bool flick = false;
orientation orient = horiz;
// setup
  Serial.begin(115200);
  ConnectSensor();
  setupSensor();
  setupNeoPixel();
  pinMode(SFX_ACT, INPUT);
  // softwareserial at 9600 baud
  ss.begin(9600);
  // can also do Serial1.begin(9600)
  while (!sfx.reset()) {
    Serial.println("Sound Board not found");
    delay(1000);
  if (HARDWARETEST) {
    if (! sfx.playTrack("BLAST01 WAV") ) {
      Serial.println("Failed to play track1");
    waitSFXFinish();
void reciveData1()
  static long int accelCombineL = 0;
  static int accelZL = 0;
  static long int gyroCombineL = 0;
  static int gyroZL = 0;
  lsm.read();
  // combine data from x and y axis to make it more simple
  long int accelCombine = sqrt( (sq((long int)lsm.accelData.x) + sq((long int)lsm.accelData.y)));
  int accelZ = (int)lsm.accelData.z;
  long int gyroCombine = sqrt( (sq((long int)lsm.gyroData.x) + sq((long int)lsm.gyroData.y)));
  int gyroZ = (int)lsm.gyroData.z;
  // Numerical differentiante
  int accelCombineDiff = abs((accelCombine - accelCombineL));
  int accelZDiff = abs((accelZ - accelZL));
  int gyroCombineDiff = abs((gyroCombine - gyroCombineL));
  int gyroZDiff = abs((gyroZ - gyroZL));
  int magz = lsm.magData.z;
  //Transfer to static variables for next time
  accelCombineL = accelCombine;
  accelZL = accelZ;
  gyroCombineL = gyroCombine;
  gyroZL = gyroZ;
  if (PRINTDATA) {
    Serial.print(accelCombine); Serial.print(',');
    Serial.print(accelCombineDiff); Serial.print(',');
    Serial.print(accelZ); Serial.print(',');
    Serial.print(accelZDiff); Serial.print(',');
    Serial.print(gyroCombine);      Serial.print(',');
    Serial.print(gyroCombineDiff); Serial.print(',');
    Serial.print(gyroZ);        Serial.print(',');
    Serial.print(gyroZDiff);    Serial.print(',');
    Serial.print(magz);       Serial.println(' ');
  // orientation detection
  if (magz < -VERTICALVAL) {
    orient = vertical;
  else if (magz > -HORIZVAL) {
    orient = horiz;
  else {
    orient = mid;
  // wrist twist detection
  if ((gyroZDiff > WRISTDIFF ) && (abs(gyroZ) > WRISTGY)) {
    wristTwist = true;
  else {
    wristTwist = false;
  // Flick detection
  if ((gyroCombineDiff > FLICKTRIG)) { // (gyroCombine > 16000) &&
    flick = true;
  else {
    flick = false;
  static bool spellCasting = false;
  static long unsigned int sampleTrig = 0; // trig for when to sample sensors
  // Take new sample
  if (millis() > sampleTrig) {
    reciveData1();
    sampleTrig = millis() + 10;
  // conect basic actions together to make difrent spells
  if (!spellCasting) {
    // trigger spell 1
    if (wristTwist && (orient == vertical) ) {
      spellCasting = true;
      sfx.playTrack("LIGHT01 WAV");
      delay(5);
    else if (wristTwist && (orient == horiz) ) {
      sfx.playTrack("WIND01  WAV");  //temp
      delay(5);
    else if (flick && (orient == horiz)) {
      sfx.playTrack("FIRE01  WAV");
      delay(5);
    else if (flick && (orient == vertical)) {
      sfx.playTrack("THUNDE~1WAV");
      delay(5);
  // spell is being cast
  else {
    // spell just finished
    if (!sfxActive()) {
EvanDallas
by EvanDallas on Thu Feb 22, 2018 12:17 am
Adafruit...any help here? Please? This is your code, project idea and product here
EvanDallas
by EvanDallas on Fri Mar 16, 2018 10:39 am
yup
EvanDallas
by adafruit_support_carter on Fri Mar 16, 2018 12:52 pm
Sorry for the delayed response. I'm seeing the same thing. The link to the zip file appears to be broken. I'll contact the guide author about that.
Piecing the code together from the snippets can be a little tough, and not something you'd normally have to do (just use the zip). So, until we get that fixed, I've done that for you. Here it is. Let me know if that works.
//from Adafruit!
#include <Wire.h>
#include <SPI.h>
// orinetation
// flick detection
// Wrist twist
// Sound
#define SFX_TX 11
#define SFX_RX 10
#define SFX_RST 18
#define SFX_ACT 23
// NeoPixels
#define PIXELPIN 9
#define NUM_LEDS 7
// IMU
enum orientation {
  horiz,
  vertical,
  mid
bool flick = false;
// setup
  connectSensor();
  setupSensor();
  setupNeoPixel();
  ss.begin(9600);
    delay(1000);
  if (HARDWARETEST) {
    waitSFXFinish();
  // Take new sample
    reciveData1();
    // trigger spell 1
      delay(5);
      delay(5);
      delay(5);
      delay(5);
  else {
    if (!sfxActive()) {
void reciveData1()
  lsm.read();
  accelZL = accelZ;
  gyroZL = gyroZ;
  if (PRINTDATA) {
    orient = vertical;
    orient = horiz;
  else {
    orient = mid;
    wristTwist = true;
  else {
    wristTwist = false;
  // Flick detection
    flick = true;
  else {
    flick = false;
/************************ MENU HELPERS ***************************/
// Is a sound playing
bool sfxActive() {
  return (! digitalRead(SFX_ACT));
// block wait till sound is finished
void waitSFXFinish() {
  delay(5);
  while (sfxActive()) {
    delay(1);
  delay(5);
// set colors in sequence
void colorWipe(uint32_t c, uint8_t wait) {
  for (uint16_t i = 0; i < strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
// set all of pixles to one color
void setColor(uint32_t c) {
  strip.show();
// set intial pixles status and set brightness
void setupNeoPixel() {
  strip.setBrightness(BRIGHTNESS);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  if (HARDWARETEST) {
    Serial.println("Testing NeoPixels");
    colorWipe(strip.Color(255, 0, 0), 50); // Red
    colorWipe(strip.Color(0, 255, 0), 50); // Green
    colorWipe(strip.Color(0, 0, 255), 50); // Blue
    colorWipe(strip.Color(0, 0, 0, 255), 50); // White
/********************** LSM9DSO ********************************/
void setupSensor()
  // 1.) Set the accelerometer range
  lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_2G);
  // 2.) Set the magnetometer sensitivity
  lsm.setupMag(lsm.LSM9DS0_MAGGAIN_2GAUSS);
  // 3.) Setup the gyroscope
  lsm.setupGyro(lsm.LSM9DS0_GYROSCALE_245DPS);
void connectSensor()
  Serial.println("Connecting to Sensor");
  // Try to initialise and warn if we couldn't detect the chip
  while (!lsm.begin())
    Serial.println("Oops ... unable to initialize the LSM9DS0. Trying again");
    delay(1000);
  Serial.println("Found LSM9DS0 9DOF");
by adafruit2 on Fri Mar 16, 2018 2:10 pm
you can find the code & files here
https://github.com/alextwin007/Magic-Wand
adafruit2
Site Admin
by EvanDallas on Fri Mar 16, 2018 3:03 pm
Ok I will try it when I can. THANK YOU!
Also note his fritzing pic doesn't match his photos of his actual build. Its a bit confusing.
EvanDallas
