CCS811 - invalid values - very small changes pls help!
Glitch_69
Post by Glitch_69 »
I have a CCS811, attached to RPi3. It seems on i2c bus, and I can run the test file from Adafruit. Everything works as expected, and as can be seen in the tutorial.
My issue is - after 48 hour burn in time, I have just a very small variance to 400 value. In a room, I have eCO2 400-420 ppm, measuring with an other device, it is abt 1200 ppm
So the value is not realistic, and almost the same,
here are some measures: https://thingspeak.com/channels/78908
All help / advise is more than welcome to fix this!!
thx in advance
Franklin97355
Re: CCS811 - invalid values - very small changes pls help!
Post by Franklin97355 »
Can you post your connections and the code you are using to test this?
Glitch_69
Post by Glitch_69 »
thx for your reply!
here is my code - simple one, im just started to learn...
#       reading ccs811
ccs =  Adafruit_CCS811()
while not ccs.available():
        pass
temp = ccs.calculateTemperature()
ccs.tempOffset = temp - 20.0
if ccs.available():
if not ccs.readData():
#       print "CO2: ", ccs.geteCO2(), "ppm, TVOC: ", ccs.getTVOC(), " temp: ", temp
        co2 = ccs.geteCO2()
        co2ok = str(co2)
        tvoc = ccs.getTVOC()
        tvocok = str(tvoc)
else:
         print "ERROR!"
this is from the adafruit example file -- and i import:
from Adafruit_CCS811 import Adafruit_CCS811
and i send co2,tvoc to thinggspeak
in regards of connection - followed the example on the link above, and the sensor is available in i2c bus, also pin wake is connected to low.
Everything works, but the data seems to be not valid, as you can see in the thingspeak chartshttps://thingspeak.com/channels/78908 - inside of the room is about 400 - 420ppm, withs is
too low.
What did I miss --- i guess, others, following the example, have the same values - -when I check tutorials, or youtube videos, more or less they
show the same 400ppm at the beginning.....
May ask you to explain, what does burn in mean? I powered up the sensor, ans run this code for two days - maybe it is a problem, and the burn in process means something else?
thx for advance!
Glitch_69
Post by Glitch_69 »
i just used a gas lighter for a few sec, abt 5cm from the sensor - and it is reacted, but the value, 805 eCO2, and 62 TVOC are too low - i guess
Glitch_69
Post by Glitch_69 »
is there someone, who would share the measured values with me pls? Im really curious , others measure similar eCO2/TVOC as me - mostly 400-420 eCO2.
These are not correct, im sure, controlled with a handheld device, the CO2 is abt 1700 ppm.
I do not understand this - em I the only one, who has this issue?????
