[SOLVED] Library ST7735 NEEDS SUPPORT for 1.54" 240x240 Wide
- adafruit2
Re: [SOLVED] Library ST7735 NEEDS SUPPORT for 1.54" 240x240
its the same as Molex 0528921095 but 12 pin, so maybe 0528921295
- solardude
Thanks for verifying that!adafruit2 wrote:its the same as Molex 0528921095 but 12 pin, so maybe 0528921295
- solardude
Is there any way I could get a schematic that shows what lines are feeding the 12 pins on this Molex connector?adafruit2 wrote:its the same as Molex 0528921095 but 12 pin, so maybe 0528921295
Or is there a link to the datasheet for the actual LCD?
- amcjen
I second this request--also would love to see the schematic for the 12 pin Molex connector.solardude wrote:Is there any way I could get a schematic that shows what lines are feeding the 12 pins on this Molex connector?adafruit2 wrote:its the same as Molex 0528921095 but 12 pin, so maybe 0528921295
Love this display!
- aglass0fmilk
I third this. Need more information about what pins are broken out by the flex cable. Bump!amcjen wrote:I second this request--also would love to see the schematic for the 12 pin Molex connector.solardude wrote:Is there any way I could get a schematic that shows what lines are feeding the 12 pins on this Molex connector?adafruit2 wrote:its the same as Molex 0528921095 but 12 pin, so maybe 0528921295
Love this display!
- solardude
@Bill @Adafruit2 Can you help us with getting the schematic for this LCD screen, please?
- adafruit2
hi we are ver busy but will post a guide soon. please check the blog and you'll see when its live!
- solardude
@Adafruit2 Good to hear!
I'm about to start on the control panel for a product and need this schematic for the LCD board before I can successfully finish the board and have the PCB's ran.
I check the blog regularly so hope to see it soon.
Please don't forget!
- toddkrein
Re: Library ST7735 NOT WORKING for 1.54" 240x240 Wide Angle
fazambuja wrote:Just tried the https://github.com/espressif/WROVER_KIT_LCD library. It uses a ST7789V
It "works" but the colors are still off. Didn't try but there is support for the Backlight.
A better solution for the Wrover-Kit is:
For anyone trying to program this via the Arduino IDE (which works well, BTW), the stock adafruit LCD libraries won’t work. See https://github.com/espressif/WROVER_KIT_LCD instead. It will save you hours of frustration… (Don’t ask me how I know.)
- adafruit2
hiya - this thread is about the 1.54" TFT - not the WROVER KIT with 2.8" TFT?
- solardude
Adafruit do you have any info on when you would be able to supply a schematic for this LCD so we can use it into our projects with custom PCB?
We have been patiently waiting for many months now.
- adafruit2
hiya we put it on github in september! :)
https://github.com/adafruit/Adafruit-1. ... 40-TFT-PCB
- solardude
Just now saw you added the schematic for this screen!adafruit2 wrote:hiya we put it on github in september! :)
I was looking for it on the product page the last 3 months!
Thanks for posting to let us know where to find it. I just bout a few more secreens for a prototype desig so good to know I can now make my own PCB for these.
