AudioFX wav trigger - doesn't show as drive, Act led on
by nathancarter on Thu Jun 21, 2018 7:36 pm
I just received my AudioFX board (Order #1781660, part #2220). It won’t show up as a drive on my computer. I’ve tried two Macs and several different cables.
Furthermore, when plugged into USB or when plugged into 5V power on the Vin/gnd pins, the Act LED is continuously on (as is the green Pwr LED). I’ve tried jumping the Rst pin, but no improvement.
I can see the VS1000B audio device on the USB bus, but not the drive.
Anything else I can try?
I emailed support, and got a (auto?) reply suggesting to post here.
Nathan
Last edited by nathancarter on Mon Jun 25, 2018 12:01 pm, edited 3 times in total.
nathancarter
Re: AudioFX wav trigger -Act led continuously on
by nathancarter on Fri Jun 22, 2018 9:50 am
Small update: I plugged it into a PC and had the same thing - red Act light is continuously on, and it doesn't show up as a drive in Windows File Explorer.
nathancarter
Re: AudioFX wav trigger - doesn't show as drive, Act led on
by nathancarter on Mon Jun 25, 2018 12:05 pm
Bumping for visibility - any other things I can do to test/diagnose, or do I need to return it for a replacement?
nathancarter
by nathancarter on Tue Jul 03, 2018 12:00 pm
Bumping for visibility, hoping for a response.
nathancarter
by adafruit_support_carter on Mon Jul 09, 2018 11:50 am
It sounds like maybe the chip didn't get fully programmed. Let's replace it. Send an email to support@adafruit.com with a link to this thread and they can take care of you.
Sorry for the delayed response on this.
by nathancarter on Mon Jul 09, 2018 11:54 am
Hi Carter,
I got in touch with support on Friday and my replacement is already on its way. I'll post back to this thread once I receive it and make sure it works.
nathancarter
by nathancarter on Thu Jul 12, 2018 1:56 pm
The replacement arrived, and worked perfectly on the first try. Thanks!
I'll share some videos in the "Show what you made" forum once it's all constructed.
nathancarter
by adafruit_support_carter on Thu Jul 12, 2018 3:43 pm
Thanks for the follow up. Glad the replacement worked! And, yes, please share your project!
