Play a random file when button is pressed for mp3 music make
by ald12 on Sun Sep 23, 2018 5:03 am
Hello, I have an arduino uno attached to an mp3 music maker. I want when a button is pressed to play a random file from the database, and to stop the play if the button is pressed again and to play another file if the button is pressed a third time. Is the below code correct? Also for the hardware, I've soldered in all the headers and attached the speakers and mounted it to the uno with power. Do I have to do anything else besides wire up the button? For the example, do I have to attach a button to an interrupt pin or anything like that?
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
int buttonPin=11;//change button number
int functionFlag;
int playFlag;
int startTime;
int endTime;
int currentTime;
char *soundBank[] = { "ALNGCHNA.ogg", "ALNGPPLE.ogg", "ALNGPUTN.ogg"
}; //sound archive
long int timerBank[]= {3000,15000, 3700
};//delays for each soundfile
// These are the pins used for the breakout example
#define BREAKOUT_RESET  9      // VS1053 reset pin (output)
#define BREAKOUT_CS     10     // VS1053 chip select pin (output)
#define BREAKOUT_DCS    8      // VS1053 Data/command select pin (output)
// These are the pins used for the music maker shield
#define SHIELD_RESET  -1      // VS1053 reset pin (unused!)
#define SHIELD_CS     7      // VS1053 chip select pin (output)
#define SHIELD_DCS    6      // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 4     // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 3       // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
  // create breakout-example object!
  Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
  Serial.begin(9600);
  musicPlayer.reset();
startTime=0;
endTime=0;
playFlag=0;
pinMode(buttonPin,INPUT_PULLUP);//set up button
Serial.println("Begin Program");
int val=digitalRead(buttonPin);
currentTime=millis();
if (val==LOW && playFlag==1 && (currentTime >= startTime+1000))
  Serial.println("Interrupt Activated");
musicPlayer.stopPlaying(true);
playFlag=0;
 //if (val==LOW && switchval==HIGH && playFlag==0)
  if (val==LOW)//when button is pressed,play sound
    Serial.println("Sound Button Activated");
    // print a random number from 0 to 80
    int randNumber = random(80);//pick a random file from the soundBank
    startTime=millis();
      musicPlayer.startPlaying(soundBank[randNumber]);
    endTime=startTime+timerBank[randNumber];
    playFlag=1;
   //allow sound to play
if (playFlag==1 && (currentTime>endTime))
playFlag=0;
 musicPlayer.stopPlaying();
ald12
Re: Play a random file when button is pressed for mp3 music
by franklin97355 on Sun Sep 23, 2018 11:32 pm
You have a few errors in your code try this.
#include <SPI.h>
#include <SD.h>
int functionFlag;
int playFlag;
int startTime;
int endTime;
int currentTime;
}; //sound archive
  Serial.begin(9600);
startTime=0;
endTime=0;
playFlag=0;
playFlag=0;
    startTime=millis();
      musicPlayer.startPlayingFile(soundBank[randNumber]);
    playFlag=1;
playFlag=0;
I have no idea if it will work but it compiles. If it does not work post the symptoms of the failure.
franklin97355
by ald12 on Thu Oct 18, 2018 3:51 am
franklin97355 wrote:You have a few errors in your code try this.
#include <SPI.h>
#include <SD.h>
int functionFlag;
int playFlag;
int startTime;
int endTime;
int currentTime;
}; //sound archive
  Serial.begin(9600);
startTime=0;
endTime=0;
playFlag=0;
playFlag=0;
    startTime=millis();
    playFlag=1;
playFlag=0;
No sound plays. The print statement "sound button activated" is hit and a print statement I added to the last if block is hit sometime later but no sound comes out. I'm using speakers as output btw.
ald12
