Adafruit Bluefruit LE UART Friend ISSUE
by tempest0 on Wed Oct 10, 2018 12:30 pm
Hello I'm trying to send just one message through Adafruit Bluefruit LE UART Friend Module like this-> https://learn.adafruit.com/assets/29595
I did this sketch:
#include <SoftwareSerial.h>
Serial.begin(9600); // (PINS: 0->TX, 1->RX)
Serial.write("Comunicando\n");
delay(1000);
UART dip switch is on, CMD is off
I plugged pin 0 (TX) from arduino uno to RXI of bluefruit module, pin 1 (RX) from arduino to TXI of bluefruit module. And VIN to 5 volts and GND to ground.
I installed Adafruit Bluefruit LE Connect app in my phone.
Blue led of CONN in bluetooth module is blinking (it is assumed that is sending message) as same time that RX in arduino is blinking.
When i connect to bluefruit bluetooth module from my phone program says UART CAPABLE but when i try to see message "Comunicando" in terminal of Adafruit app, this says Uart protocol can not be initialized.
Could somebody help me?
I would like in the future to connect two arduinos through both bluetooth modules in order to send and receive message each one from the other one.
skectch and serial monitor.jpg (153.48 KiB) Viewed 130 times
tempest0
Re: Adafruit Bluefruit LE UART Friend ISSUE
by cetronic on Thu Oct 18, 2018 5:53 am
Any help about this, pls?
Thanks for your support
cetronic
by djrosu on Mon Mar 04, 2019 2:41 am
This may be a problem with cached services. Try removing (forget) the BLE device from your android device and then scan and reconnect. Here is an link to more info.
https://devzone.nordicsemi.com/f/nordic ... 2688#32688
djrosu
by adafruit_support_carter on Mon Mar 04, 2019 11:03 pm
See the BLEUart example:
https://learn.adafruit.com/introducing- ... nd/bleuart
You are only writing to the Arduino Serial Monitor, not the BLE device. That requires:
https://github.com/adafruit/Adafruit_Bl ... e.ino#L167
For issues with app caching, see here:
https://learn.adafruit.com/bluefruit-le ... leshooting
