Erase all from I2C FRAM?
by littleninja on Fri Oct 19, 2018 3:11 pm
I need to erase everything from my Adafruit I2C FRAM breakout board but I'm not entirely sure how to, and I can't seem to find anything that helps online at all. Does anyone have any pointers?
littleninja
Re: Erase all from I2C FRAM?
by jacro on Sat Dec 01, 2018 5:35 pm
You just need to cycle through the memory and reset each byte...
#include <Wire.h>
#include "Adafruit_FRAM_I2C.h"
/* Example code for the Adafruit I2C FRAM breakout */
/* Connect SCL    to analog 5
   Connect SDA    to analog 4
   Connect VDD    to 5.0V DC
   Connect GROUND to common ground */
Adafruit_FRAM_I2C fram     = Adafruit_FRAM_I2C();
uint16_t          framAddr = 0;
void setup(void) {
  Serial.begin(9600);
  while (!Serial)
    delay(100);
  if (fram.begin()) {  // you can stick the new i2c addr in here, e.g. begin(0x51);
    Serial.println("Found I2C FRAM");
  } else {
    Serial.println("No I2C FRAM found ... check your connections\r\n");
    while (1);
  // Iterate through memory and reset each value...
  for (uint16_t a = 0; a < 32768; a++) {
    fram.write8(a, 0);
jacro
