[I2C] Can VCC pin be alternatively LOW and HIGH
by pierrot10 on Mon Dec 17, 2018 12:13 pm
I have a project with about 10 sensors:
3 moisture sensors
2 rain gauge (one for rain and one for the spray (drops)
1 sol temperaure
a RTC https://www.adafruit.com/product/3013
I also have some I2C sensors:
1) Baro BME280 https://learn.adafruit.com/adafruit-bme280-humidity-barometric-pressure-temperature-sensor-breakout?view=all
2) Lux TSL2561 https://learn.adafruit.com/tsl2561
3) IR Temperatue MLX90614 3V https://www.adafruit.com/product/1747
As my project take measures once each hour, the project sleep within about 58 minuntes. When the Adafruit MO adaloger sleep, the project consoms about 9mA.
It look a bit toomuch, then I am thinking to turn off the 3 I2C sensors (Baro, Lux and IR temperature)
I tried to leave the Baro VCC pin unconnected (open) but my project stopped working. I believe the SDA and SCl pin should be unconnected as well?
Or should I connect all of my I2C VCC pins to a pin of my Arduino MO adaloger and put it LOW when the microcontroller sleep, and HIGH when I need to take a measure?
If yes, should I re initiate the I2C sensor when they are reactive as for example with the BME280:
      if (!bme.begin()) {
        Serial.println("Could not find a valid BME280 sensor, check wiring!");
        while (1);
Second question regarding TSL2451:
I red that TSL2451 can be in sleep mode, The doc say
about 0.5mA when actively sensing, and less than 15 uA when in powerdown mode.
In the ccp file, there is disable function but if in my ino file I write
tsl.disble();
The IDE generate an error stating the disable() is private.
Then I wonder how can I use tsl.disable() and make sure that TSL2561 goes in low power when inactive (no measuring)
Many thank for your support and Merry Christmas to all of you!!
pierrot10
Re: [I2C] Can VCC pin be alternatively LOW and HIGH
by pierrot10 on Wed Jan 09, 2019 5:15 am
No body can help?
pierrot10
by adafruit_support_bill on Wed Jan 09, 2019 8:53 am
Removing VCC power from the board, the pullup resistors on the SDA and SCL lines effectively become pull-down resistors. So I2c communication will be adversely affected.
by pierrot10 on Wed Jan 09, 2019 9:03 am
Dear Bill
Thanks for your reply. I pulled up the I2C pin of my microcomtroller
I did not exactly understand your answer.
If my I2C lines are pulled up with a 4.7K resistance and if I leave the VCC pin of my I2C sensors, the SDA and SCl pin of the I2C sensors will be pulled down by the sensor enven if I pulled up the I2C line???
In any case the VCC pin can not be open, but it be to the ground to switch it off???
pierrot10
by adafruit_support_bill on Wed Jan 09, 2019 2:24 pm
If there is no VCC applied, the voltage on that rail is undefined - but probably would tend toward ground potential. So the pullup resistors on the board will not be pulling "up".
If you have other pullup resistors on the i2c bus, you can probably get away with removing the ones on the breakout.
by pierrot10 on Wed Jan 09, 2019 2:29 pm
Thank again for your reply.
Then in other work, the I2C sensor must be powered at VCC :)
pierrot10
by millercommamatt on Wed Jan 09, 2019 3:32 pm
Would something like this work for you?
https://www.adafruit.com/product/3435
millercommamatt
