TTL camera
TTL camera
by jdelcamp11 on Wed Dec 19, 2018 5:32 pm
I recently purchased a serial ttl jpeg camera (weatherproof version PID 613.
I am not able to get the camera to work.
I have tried the comm tool, the snapshot example, the NTSC output.
I have tried switching the RX/TX lines.
I have tried all the baud rates in the comm tool.
I have tried giving it it's own 5V power.
The IR leds glow slightly, but no output and not communication with the camera.
My other camera non-weatherproof version works perfectly in the same setup.
I would like to arrange for an exchange.
jdelcamp11
Re: TTL camera
by adafruit_support_carter on Thu Dec 20, 2018 9:27 pm
Can you post a photo of your setup showing how you have everything connected.
Were you trying to use this library?
https://github.com/adafruit/Adafruit-VC ... ra-Library
and run the example?
https://github.com/adafruit/Adafruit-VC ... apshot.ino
Re: TTL camera
by jdelcamp11 on Sat Dec 22, 2018 4:31 pm
Your library doesn't work as is with my due or feather MO. I have modified it to remove any reference to softserial. This works well with both my due and featherMO. The same with the sketch. I am using Serial3 on my Due and Serial1 on my feather. I am attaching both the modified library and sketch.
I know this works as I am using them with my other camera. I wanted to replace it with the waterproof version.
I also want to mention that the camera should still produce a composite video - but doesn't.
I will add the photo in a separate post.
Due_VC0706.h
(3.36 KiB) Downloaded 11 times
Snapshot.ino
(5.96 KiB) Downloaded 13 times
Due_VC0706.cpp
(10.8 KiB) Downloaded 12 times
jdelcamp11
Re: TTL camera
by jdelcamp11 on Sat Dec 22, 2018 4:33 pm
photo of setup.
Note: the feather MO is a 3.3V so the voltage divider isn't required.
jdelcamp11
Re: TTL camera
by adafruit_support_carter on Sun Dec 23, 2018 2:29 pm
You're powering it from 3.3V in your photo. In your first post you mention giving it 5V - which is what it needs. The video out should be a good check. Were you powering it from 5V when you did the video check? What are you using for an actual display for testing the video output? Is it the same one that works with the other camera?
Re: TTL camera
by jdelcamp11 on Sun Dec 23, 2018 4:57 pm
Yes, when I did the video out check I had it powered by 5V. Composite to my TV. Same tv, same composite cable, and same setup.
My other camera works perfectly in the setup as pictured. I just confirmed with my other camera that I also get composite when powered at 3.3V. The new camera, when powered by either 5v or 3.3v does not. I don't see the leds faintly glowing at 3.3v (expected).
jdelcamp11
Re: TTL camera
by adafruit_support_carter on Sun Dec 23, 2018 5:23 pm
The RCA connector is just out of view in your last photo. Can you post another one showing the solder job there. Where the brown and yellow cables go.
Re: TTL camera
by jdelcamp11 on Mon Dec 24, 2018 10:15 am
20181224_075853 (2).jpg (343.03 KiB) Viewed 154 times
jdelcamp11
Re: TTL camera
by adafruit_support_carter on Mon Dec 24, 2018 1:20 pm
Thanks for the photos. For the analog video, should just be able to apply the 5V power and get it on the RCA jack. Finding something that can display NTSC is getting more and more difficult - but you've got something that works with your other camera. Not sure. Let's replace it.
Send an email to support@adafruit.com with a link to this thread and your order number and they can get you a replacement weatherproof camera PID 613.
Re: TTL camera
by jdelcamp11 on Mon Dec 24, 2018 4:23 pm
I will post a follow-up after the replacement arrives.
jdelcamp11
Re: TTL camera
by jdelcamp11 on Thu Jan 03, 2019 11:26 pm
I received the replacement camera today. It worked right out of the box.
Thanks for the support.
jdelcamp11
Re: TTL camera
by adafruit_support_carter on Fri Jan 04, 2019 12:34 pm
Cool. Thanks for letting us know. Glad the replacement worked and thanks for trying to troubleshoot the other one with us.
Re: TTL camera
by jdelcamp11 on Fri Jan 11, 2019 10:49 am
I never received a shipping label or instructions for returning the defective camera.
jdelcamp11
Re: TTL camera
by adafruit_support_carter on Fri Jan 11, 2019 12:24 pm
No worries. That just means we don't need it returned. If your new camera works, then you're all set. Thanks for asking though.
