Adafruit Audio FX Mini Sound Board - No Red Light
by seorakwak on Sat Dec 22, 2018 1:58 am
I got the green light to come on, but I'm having trouble triggering the sounds (I don't even get a red light when I connect ground to any # pin). I downloaded the example sounds from the adafruit tutorial onto the soundboard. I'm wondering if my speaker setup is incorrect; I have connected L to the power band on the aux cable of my powered speaker and GND to the ground band of my powered speaker. However, if I have a wire connected from ground to any # pin, is the red light supposed to come on, regardless of whether or not a speaker was plugged in correctly?
Thank you,
Grace
seorakwak
Re: Adafruit Audio FX Mini Sound Board - No Red Light
by Onegalos on Sat Jan 12, 2019 9:11 pm
I had the same problem the problem lies within the instructions ... the instructions say T01HOLDL.wav , leave the .wav off the back of the file when you rename it and it will work also use a Sound file converter like Audacity drop from 32bit to 16bit change the hrz to 6000
Onegalos
by adafruit_support_carter on Thu Jan 17, 2019 3:15 pm
@seorakwak Yes. The red light should come on. However, keep in mind playback won't work if you are still connected to the PC via USB:
https://learn.adafruit.com/adafruit-aud ... owering-it
