si7021 problems
- Jayveesea
si7021 problems
I'm having some difficulty with my si7021 temp/humidity sensors (ordered back on black friday). I have each sensor connected to it's own Huzzah ESP8266 and periodically posting temp/humidity via MQTT. I've placed both systems next to my Nest and an Accurite temp/humidity sensor. The Nest and Accurite agree on humidity (within 1% RH) but both si7021's are reading about 10% RH higher than the other two (temperature seems ok) and they've all been sitting there for several days. Is there any tricks to getting better accuracy or do I have some bad sensors?
- Jayveesea
Re: si7021 problems
The trend continues with these devices over the last few days. The si7021's consistently read 10-12% RH higher than my other devices.
- adafruit_support_carter
Re: si7021 problems
Which library are you using with the Si7021?
- millercommamatt
Re: si7021 problems
How to the temperatures compare? If your reference sensors are reading warm, the reported RH could be low.
- Jayveesea
Re: si7021 problems
the reference temps read about 1.5degF higher than the si7021s.
- Jayveesea
Re: si7021 problems
I'm using Adafruit's "Adafruit_Si7021".adafruit_support_carter wrote:Which library are you using with the Si7021?
Here's my code.
Re: si7021 problems
What are the RH and temperature levels you are operating at?
- millercommamatt
Re: si7021 problems
An air temperature of 24 C over a dew point of 10 C equals an RH of 41.7%. An air temperature of 26 C over the same dew point equals an RH of 36.5%. The difference in RH could just come down to a different in temperature. For the same absolute humidity, the relative humidity is a function of air temperature.
- Jayveesea
Re: si7021 problems
Temperatures right now are about 65 to 70degF, RHs right now are about 30-45%.adafruit_support_carter wrote:What are the RH and temperature levels you are operating at?
Thanks, I think this must be a source of some of the error, but I've been seeing about 10-12% difference between my Nest and Acurite and the si7021's. Considering the sensor accuracy for each of them might account for the remaining discrepancy.millercommamatt wrote:An air temperature of 24 C over a dew point of 10 C equals an RH of 41.7%. An air temperature of 26 C over the same dew point equals an RH of 36.5%. The difference in RH could just come down to a different in temperature. For the same absolute humidity, the relative humidity is a function of air temperature.
That being said, the Acurite is reading 66degF and 37% RH, and the si7021 is reading 66degF and 46% RH right now and they are sitting right next to each other... so I'm not totally convinced that this thing is operating correctly.
