I am attempting to install an Adafruit FT232H on a computer. I used this tutorial https://learn.adafruit.com/adafruit-ft2 ... dows-setup,
When I installed it on a different computer, I had no troubles finding the the FT232H on Zadig as FTDIBUS. Now, on this new computer, I am seeing something with the same ID number (0403 6014) but with a different name than FTDIBUS (Unknown Device 1). Is this unknown device the Adafruit FT232H that I want to convert?
ZADIG not recognizing FT232H
- Franklin97355
Re: ZADIG not recognizing FT232H
Make sure you have installed the FTDI drivers if you are using Windows.
- scrimi09
Is it possible that you could link me to the correct driver? I have Windows 7 64 bit pc.
Thanks,
Sarah C
Thanks,
Sarah C
- scrimi09
Actually, there is one thing that I forgot to mention that might be relevant. I am accessing this machine remotely. Is it possible that this is the driver I need is here?
https://www.ftdichip.com/Drivers/VCP.htm
Thanks,
Sarah Crimi
Thanks,
Sarah Crimi
- scrimi09
Hello,? Does anyone know the answer to this? This is very frustrating.
Thanks,
Sarah C
Thanks,
Sarah C
- Franklin97355
Those should work.
