DHT11 NC Pin
DHT11 NC Pin
by felipedmsantos on Thu Jan 10, 2019 7:58 pm
Hi, I bought the DHT11 sensor and I'm curious about the fact that to have a NC Pin. What the utility this? I've searched in online foruns, but I only find speculations about factory calibrations, that is, nothing concrete... Someone can take off this curiosity definitifly?
felipedmsantos
Re: DHT11 NC Pin
by franklin97355 on Thu Jan 10, 2019 8:32 pm
NC = Not Connected in this case. It can also mean Normally Closed in relation to a switch or relay.
franklin97355
Re: DHT11 NC Pin
by felipedmsantos on Thu Jan 10, 2019 8:42 pm
Thanks for the reply, but the point of this question is: If I cant use this pin, why It exists?
felipedmsantos
Re: DHT11 NC Pin
by franklin97355 on Thu Jan 10, 2019 10:50 pm
The product is made by a Chinese company so you would have to ask them. https://cdn-shop.adafruit.com/datasheets/DHT11-chinese.pdf
franklin97355
Re: DHT11 NC Pin
by felipedmsantos on Fri Jan 11, 2019 3:46 pm
Okay, i'll do this, one more time thanks for the reply!
felipedmsantos
Re: DHT11 NC Pin
by millercommamatt on Fri Jan 11, 2019 4:00 pm
My guess is that other sensors like the DHT12 are built with the same form factor and likely with the same PCB. All 4 pins are used on the DHT12. It's likely cheaper to make one board used for multiple products and just leave the unused pins in place.
millercommamatt
