Powerboost C battery low voltage cutoff
by jaymaster2000 on Thu Jan 10, 2019 10:17 pm
Hi Adafruit forum,
I've looked through the product information for the Powerboost C devices and can't seem to see if it mentions if it cuts off the battery at a specific threshold, the device has a warning led to indicate the battery is in low state, but can anyone confirm if it cuts the voltage if the voltage is too low?
jaymaster2000
Re: Powerboost C battery low voltage cutoff
by franklin97355 on Fri Jan 11, 2019 12:27 am
The low voltage cutoff is handled by the circuit in the battery, not the charger.
franklin97355
by jaymaster2000 on Fri Jan 11, 2019 12:34 am
Thanks for the clarification, so I can't use a battery without a BMS then.
jaymaster2000
by franklin97355 on Fri Jan 11, 2019 12:57 am
It's not recommended.
franklin97355
