Received broken foot pedal potentiometer in the mail
by pacamac1 on Thu Feb 14, 2019 8:06 pm
I ordered 2 foot pedal potentiometers.
https://www.adafruit.com/product/3739
One of the potentiometers came broken in the mail and was wrapped less securely than the other one.
It stays at only 20k ohms even when pressed.
There is a loose part that can be heard hitting the case when the case is shaken or moved.
May I get a replacement or help repairing the broken part?
pacamac1
Re: Received broken foot pedal potentiometer in the mail
by franklin97355 on Fri Feb 15, 2019 2:30 am
Go ahead and try taking it apart. If you can restore the part to where it goes let me know. Post a picture when you get it open.
franklin97355
by pacamac1 on Sun Feb 17, 2019 12:47 pm
Here is the picture of the inside of the broken foot pedal.
There is a small spring with a screw attached to it that seems to be broken off from another piece.
This small spring is what was moving around the case.
There is also a sticky residue on the broken off spring.
I am not sure if it is glue or melted plastic.
pacamac1
by franklin97355 on Sun Feb 17, 2019 4:56 pm
Thanks for investigating the problem. Please contact support@adafruit.com with a link to this topic and they will get you a replacement pedal.
franklin97355
by pacamac1 on Tue Feb 19, 2019 1:59 am
Thank you!
pacamac1
