Hi.
I failled to use the Adafruit 2.7" Tri-Color eInk / ePaper Display with SRAM - Red Black White ID: 4098 with a feather M4 and circuitpyton.
I succeed with the arduino driver (Adafruit_IL91874 epd) but i don't find this driver in the circuitpython repository (only the Adafruit_IL0373 epd).
Is there a tips to use it with circuitpython or the driver is just no yet ready?
Sorry for my poor english level and if i put my question in a wrong place.
Cordially
Edwin
Adafruit 2.7" Tri-Color eInk/ ePaper Display, circuitpython
- ed_win
- adafruit_support_carter
Re: Adafruit 2.7" Tri-Color eInk/ ePaper Display, circuitpyt
Can you post your CircuitPython code.
- ed_win
Hi,adafruit_support_carter wrote:Can you post your CircuitPython code.
Here is the code I used.
The only change I made to the example are pin number and resolution:
import digitalio
import busio
import board
from adafruit_epd.epd import Adafruit_EPD
from adafruit_epd.il0373 import Adafruit_IL0373
# create the spi device and pins we will need
spi = busio.SPI(board.SCK, MOSI=board.MOSI, MISO=board.MISO)
ecs = digitalio.DigitalInOut(board.D10)
dc = digitalio.DigitalInOut(board.D9)
srcs = digitalio.DigitalInOut(board.D5)
rst = digitalio.DigitalInOut(board.D11)
busy = digitalio.DigitalInOut(board.D6)
# give them all to our driver
display = Adafruit_IL0373(264, 176, rst, dc, busy, srcs, ecs, spi)
# clear the buffer
display.clear_buffer()
r_width = 5
r_pos = display.height
color = Adafruit_EPD.BLACK
while r_pos > display.height/2:
if r_pos < display.height - 50:
color = Adafruit_EPD.RED
display.rect(display.width - r_pos, display.height - r_pos,
display.width - 2*(display.width - r_pos),
display.height - 2*(display.height - r_pos), color)
r_pos = r_pos - r_width
display.display()
Cordially
Edwin
Thanks. Looks like you're running the example from here:
https://learn.adafruit.com/adafruit-ein ... ython-code
Can you post a photo showing how you have the display wired to your main board.
- ed_win
I don't success to have a readable picture: feather M4 -> 2.7 eink:adafruit_support_carter wrote:Thanks. Looks like you're running the example from here:
3V -> VIN
-> 3v3
Gnd -> GND
SCK -> SCK
MO -> MOSI
MI -> MISO
11 -> RST
10 -> ECS
9 -> D/C
6 -> Busy
5 -> SRCS
-> SDCS
-> ENA
I also try with:
13-> busy
12 -> SRCS
With the pin modified code.
With no success.
That seem to work with the same wiring and arduino example code.
Cordially
Edwin
It may be soldering related - it looks a little thin on some of your pins. But since it worked OK using Arduino, let's not worry about that yet.
It looks like your wiring and code modification are OK. When you ran the CircuitPython code, did the display do anything? You saw with the Arduino - the refresh is pretty slow and flashes the screen a bit. Did you see any of that?
As another test - can you back to Arduino and make sure it still works there. Try changing the output to something else and make sure the display updates to that. That way we'll know it's just a CircuitPython issue.
- ed_win
With all of this test, i noticed something:
The circuit python code seem to display with success the content of SRAM:
- if i use arduino code before and without disconnect the feather switch to circuitpython, it display exactly the same picture than previously with arduino.
- if i run the circuitpython directly after switch-on, it display a bunch of pixels. I suppose the SRAM is 'empty' due to switch off. The UF2 file i use is this one:
https://github.com/adafruit/circuitpyth ... -3.1.2.uf2
The beginning of the VERSIONS.txt file is as follows ( I use https://github.com/adafruit/Adafruit_Ci ... 190226.zip):
Thanks a lot for your time.
Cordially
Edwin
When I ran the circuitpython code the display refresh. The refresh is pretty slow and flashes the screen a bit.When you ran the CircuitPython code, did the display do anything? You saw with the Arduino - the refresh is pretty slow and flashes the screen a bit. Did you see any of that?
Yes it still work.As another test - can you back to Arduino and make sure it still works there
Yes it still work on arduino but not on circuitpython. I tried to change every wire except hardware spi (MOSI/MISO/SCK).Try changing the output to something else and make sure the display updates to that
20190225
https://github.com/adafruit/Adafruit_CircuitPython_74HC595/releases/tag/1.0.2
https://github.com/adafruit/Adafruit_CircuitPython_ADS1x15/releases/tag/1.0.2
https://github.com/adafruit/Adafruit_CircuitPython_EPD/releases/tag/1.2.1
Cordially
Edwin
- adafruit2
woops shoot we thought it was the same chipset. please subscribe to this issue https://github.com/adafruit/Adafruit_Ci ... D/issues/8 we'll update it as soon as we port over the new driver.
- ed_win
Done.adafruit2 wrote:woops shoot we thought it was the same chipset. please subscribe to this issue https://github.com/adafruit/Adafruit_Ci ... D/issues/8 we'll update it as soon as we port over the new driver.
Thanks a lot for your reactivity, it's a real pleasure to play with your product.
Cordially
Edwin
- ed_win
It works very well with the new driver! Thank's a lot!
I don't know if it's normal but I needed to copy the font5x8.bin file ( located in the exemple folder) to the root of CIRCUITPY(D:).
Thank's again.
Edwin
Thank's again.
Edwin
- adafruit2
yep thats normal
