DIY USB Cable Parts - Straight Type C Plug
by switchback on Sat May 18, 2019 1:57 am
This part has two surface mount devices and two solder pads. What is the purpose of these items?
I ask because I'd like to make a USB-C to USB-B micro cable using this system.
I did put one together and it did not seem to work.
After some research I found that a cable of this type requires some resistors and a specific wiring scheme.
I'm hoping the solder pads allow this configuration.
I tried tracing with a multimeter but the traces are very tiny.
Do you have a schematic? or any advice/instructions?
switchback
Re: DIY USB Cable Parts - Straight Type C Plug
by AMandaC on Mon May 20, 2019 3:43 pm
switchback wrote:This part has two surface mount devices and two solder pads. What is the purpose of these items?
I did put one gimp freejobalert notepad++ together and it did not seem to work.
I also have the same question and need some advice/help. Help is appreciated.
Thanks in advance.
Regards,
Amanda
AMandaC
by switchback on Sun May 26, 2019 10:24 pm
bump!
switchback
