Issue when program run through battery
by amitshishodia on Wed Jun 12, 2019 3:00 am
Dear all
i am facing some problem
1. I have use feather m0 adalogger board i have connected my board to USB as well as battery. i have measure the battery voltage at pin 9 (A7) it show half of the BAT pin of board. With the help of battery voltage i have blinking LED on pin 10 when board connected to USB program properly work(if and else condition both are work) and when i remove USB(only battery connect) program not work properly only else condition are work.
const int ledPin = 12;
  // initialize serial communication at 9600 bits per second:
  Serial.begin(9600);
  pinMode(ledPin, OUTPUT);
// the loop routine runs over and over again forever:
  // read the input on analog pin 0:
  int Batteryvoltage = analogRead(A7);
  // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
  float voltage = (Batteryvoltage * (3.3 / 1023.0)*2);
  // print out the value you read:
  Serial.println(voltage);
  if (voltage<3.1)
  digitalWrite(ledPin, HIGH);
  delay(100);
  digitalWrite(ledPin, LOW);
  delay(100);
  else
  delay(1000);
  delay(1000);
amitshishodia
Re: Issue when program run through battery
by adafruit_support_bill on Wed Jun 12, 2019 5:49 am
Your calculation is assuming an analog reference voltage of 3.3v. If the battery voltage drops to 3.3v, the Feather's 3.3v voltage regulator can no longer produce a 3.3v regulated output. So the analog reference voltage will always be less than the battery voltage and your voltage calculation will not be accurate.
