MAX9744 Amplifier not working
Re: MAX9744 Amplifier not working
by adafruit_support_carter on Mon Aug 05, 2019 8:14 pm
Would you recommend I use the 1A DC wall power supply instead of the one in the photo above?
For now, only because it sounds like a more simple power supply. 1A should be enough to get you some output. It may not be enough for full volume output.
Is anything getting hot on the board?
And let's double check your speakers also.
...along with the 2 recommended speakers
Can you link to which ones these are.
by ThaHarvesta on Sat Aug 10, 2019 10:27 pm
Sorry for the late reply. Nothing on the board is heating up, should I be expecting any LED signals on the board? Thank you for the advice with the 1A wall power supply, I will use that from now on. I bought 2 of these speakers:
https://core-electronics.com.au/20w-4-o ... f1027.html
They were recommended by Core Electronics in the MAX9744 details.
ThaHarvesta
by adafruit_support_carter on Mon Aug 12, 2019 1:26 pm
Unfortunately, there aren't any indicator LEDs on the board. Let's double check this other power supply. Can you post photos of the 12V / 1A supply you are using now.
by mengjialyu on Mon Aug 24, 2020 6:43 pm
Dear Adafruit,
I am working on a very similar project, and am confused about the fact that my power source can only supply 0.03A under 12V DC. I wonder if this is why the audio output has a low volume even though I set the volume to highest in i2c. Could you please provide some input? Thank you!
Best,
Mengjia
mengjialyu
by adafruit_support_carter on Mon Aug 24, 2020 6:51 pm
@mengjialyu Please start a new thread for your issue.
