Solar Panel adapter doesn't fit
by GregSawin on Wed Sep 04, 2019 1:30 pm
Not sure if I got a defective product but the solar panel (Small 6V 1W Solar Panel - Silver: https://www.adafruit.com/product/3809) plug won't fit the suggested adapter (3.8 / 1.3mm or 3.5 / 1.1mm to 5.5 / 2.1mm DC Jack Adapter Cable: https://www.adafruit.com/product/2788). As best as I can measure both sides do look like to be the right size. 3.46OD on the solar panel connection, 3.52ID on the adapter. I can't easily measure the inner pin on the adapter, it's too recessed, but I'm guessing it's not fitting inside the adapter.
GregSawin
Re: Solar Panel adapter doesn't fit
by adafruit_support_mike on Thu Sep 05, 2019 3:01 am
Hmm.. I'll have someone pull a couple of units and see if the connector has changed.
I remember a similar report a few years ago, where it turned out the connectors required a fairly strong push to seat properly. We can check to see if that's still the case.
by jdelcamp11 on Thu Sep 05, 2019 8:15 pm
I just received my adapter today and have the same issue. I did try a significant amount of force with no luck.
I really didn't want to clip off the jack but looks like the only way now.
jdelcamp11
by jdelcamp11 on Fri Sep 06, 2019 4:36 pm
I just spotted this on your new porducts page -> 3.5mm / 1.1mm to 5.5mm / 2.1mm DC Jack Adapter
PRODUCT ID: 4287
Can someone at Adafruit confirm it actually fits the solar panels you sell -> Small 6V 1W Solar Panel - Silver
PRODUCT ID: 3809
jdelcamp11
by GregSawin on Wed Sep 11, 2019 11:48 am
adafruit_support_mike wrote:Hmm.. I'll have someone pull a couple of units and see if the connector has changed.
What did you find?
GregSawin
by adafruit_support_mike on Wed Sep 11, 2019 12:11 pm
The products team said they had a similar report a few weeks ago and checked the connectors then, and they worked.
They said to try one of these adapters though:
https://www.adafruit.com/product/4287
Send a note containing a link to this page and your order number to support@adafruit.com. The folks there will send you the adapter.
by jdelcamp11 on Wed Sep 11, 2019 5:03 pm
I tried again and was able to force the cable onto the existing jack. It did take some work, but it fit.
Thanks for checking.
jdelcamp11
by GregSawin on Mon Sep 16, 2019 1:33 pm
The 4287 adapter fits, thanks.
GregSawin
cron
