SDA or SCL needs a pull up
Re: SDA or SCL needs a pull up
by adafruit_support_carter on Thu Sep 12, 2019 1:24 pm
It's finding it, just not at the default address (0x70). Are you still jumpering the A0/A1/A2 pins to the power rail as in your photo above? To specify the non-default I2C address for the TCA, you need to specify it when setting up the TCA object:
https://github.com/adafruit/Adafruit_Ci ... 8a.py#L105
by geekguy on Thu Sep 12, 2019 7:11 pm
adafruit_support_carter wrote:It's finding it, just not at the default address (0x70). Are you still jumpering the A0/A1/A2 pins to the power rail as in your photo above? To specify the non-default I2C address for the TCA, you need to specify it when setting up the TCA object:
I completely spaced out having to specify the address when I jumper the TCA9548A to a different address. I am now suitably humbled at this oversight. Everything is working now, and I have learned much!
Thank you for your patience!
8-Dale
geekguy
