Problem with the BMO055 sensor on the Raspberry PI
by Hansom on Thu Sep 12, 2019 4:09 pm
Hello ladies and gentleman.
I have bought a BMO055 sensor and connected it to the raspberry pi3 according to the adafruit manual. The sensor is connected via serial and PS1 is soldered to the 3.3v line enabling UART.
When i execute the simpletest.py script i get following error message:
  File "simpletest.py", line 45, in <module>
    if not bno.begin():
  File "build/bdist.linux-armv7l/egg/Adafruit_BNO055/BNO055.py", line 382,
in begin
  File "build/bdist.linux-armv7l/egg/Adafruit_BNO055/BNO055.py", line 358,
in _config_mode
  File "build/bdist.linux-armv7l/egg/Adafruit_BNO055/BNO055.py", line 416,
in set_mode
  File "build/bdist.linux-armv7l/egg/Adafruit_BNO055/BNO055.py", line 311,
in _write_byte
  File "build/bdist.linux-armv7l/egg/Adafruit_BNO055/BNO055.py", line 258,
in _serial_send
  File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 538,
in write
    raise writeTimeoutError
serial.serialutil.SerialTimeoutException: Write timeout
i have searched the forums and did everything suggested in this post:
viewtopic.php?f=8&t=96471
unfortunately it didn't help. I get still the same error message.
I have no idea what i could do to solve this issue. I have double and tripple checked the connections and everything is according to the manual. (I changed the rst pin from pin 18 to pin 23 because i have already connected something on pin 18, but i changed the pin in the script...)
is it possible that the device is broken?
Thanks a lot in advance.
Best wishes
Hansom
Hansom
