Adafruit DIY cable connector
by astoneng on Fri Sep 13, 2019 2:30 pm
I'd like to use an Adafruit DIY USB/HDMI cable with a custom board. However I cannot find any hardware files or schematics that would point to what spec FFC connector I would need for my custom board, to interface with the cable.
Does anyone know the pitch, thickness, # of pins on these connector cables? Or perhaps the p/n used on the adapter boards?
Many thanks,
Jake
astoneng
Re: Adafruit DIY cable connector
by mikeysklar on Mon Sep 16, 2019 7:07 pm
Good question. I'm kind of surprised that is not available in Technical Specs section.
The FFC connectors are on our DIY HDMI / USB boards are 20-pin with 0.5mm pitch.
mikeysklar
by spacedcowboy on Tue Oct 15, 2019 12:06 pm
Along the same lines, do you happen to have the pinouts used on the connector. It *looks* like the first 8 pins on the 20-way are one signal, then the next two are another, the next two are another and the last 8 are ganged together.
So, I'm guessing it's +5v, D+, D- and GND ? Be good to know the order though :)
spacedcowboy
by mikeysklar on Wed Oct 16, 2019 5:57 pm
Pulled from a raspberry Pi forum. Ignore the "recommended signal layout".
FFC
FFC
mikeysklar
by spacedcowboy on Thu Oct 17, 2019 12:58 pm
That's good for HDMI :)
Do you have the link to the r-pi forum so I can see if they've got the USB pinouts there ?
Cheers
Simon
spacedcowboy
by mikeysklar on Thu Oct 17, 2019 6:16 pm
mikeysklar
cron
