Touch screen as a second display on Win 10
by oleglego on Sun Sep 15, 2019 1:31 pm
Dear All
I am wondering if it is possible to use the USB touch screen ( https://www.adafruit.com/product/2407 )
as a second display in the extended display mode such that touch sensor would work within the touch screen only.
Otherwise by default the touch screen area is extrapolated to the total (display 1 + display 2) area.
oleglego
Re: Touch screen as a second display on Win 10
by mikeysklar on Sun Sep 15, 2019 2:27 pm
We have not tested this so no guarantee here.
I suspect extended desktop mode will work with Windows 10 assuming your existing display is not a touch screen.
You should can configure this through :
Control Panel/TabletPC/calibration
Windows Key + P to select extended mode
mikeysklar
by oleglego on Sun Sep 15, 2019 3:56 pm
The calibration button is disabled (see attached). Can it be because the screen is not recognised as a touch screen?
The primary display is not a touch screen.
adafruit touch screen calibration.png (82.62 KiB) Viewed 81 times
oleglego
by mikeysklar on Sun Sep 15, 2019 4:07 pm
You can try some suggestions here for disabling / enabling touch screen devices on win10. It could require a driver rollback to work.
https://www.makeuseof.com/tag/fix-touch ... indows-10/
mikeysklar
by oleglego on Mon Sep 16, 2019 4:17 am
Thank you for the reply.
Unfortunately it did not help. I cannot roll back the driver (it is disabled).
The screen is recognised as an "USB Input Device" and not as an "HID-compliant touch screen". Basically a mouse.
Do you have your driver for the screen?
afafruit screen - roll back driver disabled.png (147.47 KiB) Viewed 60 times
oleglego
