I have a device which are both communicating using NFC and broadcasting using RFID.
NFC
Standard: ISO / IEC 14443 A+B
NFC Type: Type 2
NFC Data Exchange Format: NDEF
RFID
Standard: ISO / IEC 18000-63 (gen 2)
Band: EPC Gen2 (860 to 960 MHz)
I have found this board:
Adafruit PN532 NFC/RFID
https://www.adafruit.com/product/789
And the library:
https://github.com/adafruit/Adafruit-PN532/
Can anyhelp with me with the simplest form of NFC read record and RFID read tag?
Thanks.
Adafruit PN532 NFC/RFID: How to read NFC and RFID
- A_E_M
- oesterle
Re: Adafruit PN532 NFC/RFID: How to read NFC and RFID
Hi, A_E_M!
Welcome to the Forums!
Check out the primary product guide for the Adafruit PN532 RFID/NFC Breakout and Shield. It has instructions to get you started quickly reading the IDs of tags, in either Arduino or CircuitPython.
If you're using Arduino, once you've installed Adafruit's PN532 library, in the Arduino IDE navigate to:
File > Examples > Adafruit_PN532 > readMifare
There's also a Python & CircuitPython section that will guide you through wiring and coding your PN532 for boards that support CircuitPython, and for Raspberry Pi.
You can use the PN532 to store information on some tags and read it back later, like the ones in the 13.56MHz RFID/NFC tag assortment - Classic 1K.
There are more NFC/RFID project ideas and tutorials in the Adafruit Learning System.
What are you making?
Cheers,
Eric
Cheers,
Eric
- A_E_M
Thanks a lot for your input.
I'm making a reader that can read tags that I have not programmed. They contain information in both NFC and RFID.
I have found a NFC reader app on my phone, and it can read 3 "records" from the tags. I would like to read those records using the Adafruit board. Is that possible, or can it only read the IDs?
Based on the examples, I cannot see how RFID works?
Thanks for your time!
- oesterle
Radio-frequency identification (RFID) technologies work at various frequencies, protocols, power levels, and distances. Near Field Communication (NFC), as I understand it, is a kind of RFID, and is a specific set of communication protocols designed to work at very close distances (4cm/1.5in or less).
NFC Data Exchange Format (NDEF) standardizes ways of encoding small amounts of data, like URIs, phone numbers, etc, as “records.”
The Adafruit PN532 primary product guide discusses those record formats in the section, About the NDEF Format.
The adafruit/Adafruit-PN532 library includes examples for reading and writing NDEF records.
Running the examples with my PN532 board and tags helped me understand the capabilities, and I was able to use and modify example code for prototypes I built.
You also mention wanting to support:
You'll need a different board to read and write EPCglobal Gen 2 tags. (The PN532 board does not support this.)Standard: ISO / IEC 18000-63 (gen 2)
- A_E_M
Thanks for your input.
When I use an app for my phone (called NFC Tools), I can read the tag and the app displays the following information:
* Tag type: ISO 14443-3A, NXP MIFARE Ultralight
* Technologies: NfcA, Ndef
* Data format: NFC Forum Type 2
* And then it has 3 "records" with the actual data.
I believe that since my mobile can read this tag, then the Adafruit PN532 can do that as well?
Also, I'm not use I understand how to instruct the library to scan a RFID tag instead of a NFC tag?
- A_E_M
BTW: Thanks for the link to the explanation of NDEF
https://learn.adafruit.com/adafruit-pn532-rfid-nfc/ndef
That is what I want. That explains very well the concept of NDEF records.
But I do not see an example in the library that can read a NDEF record? The readMifare example seems not to read NDEF records?
Thanks.
Thanks.
Hi I think my problem is the same as in this topic. I hope some one can help me.
I have a NFC handheld sensor device, which data I want to read out with my PN532 shield with Arduino.
Unfortunately I was not able to read out the data, at least the relevant information for me. I guess this is the NDEF message.
When I read out the handheld device with my smart phone I'll get this output with all the relevant information I need:
My Arduino runs with this example code from "all about circuits". With the examples from the PN532 Library from Adafruit I was not successful.
The output over the serial monitor is as follows:
As you can see, the message will not be shown.
Does anybody knows what I need to change in the code to view the message contents, manly the measurement data is important.
▪▪ DATA ▪▪
Date Time,Oechsle [deg] ,Brix [%] ,Temp [degC]
2019/09/28 11:18:20, -1, -0.2, 23.7
2019/09/28 11:19:03, -1, -0.2, 23.7
2019/09/28 11:19:13, -1, -0.2, 23.7
2019/09/28 11:19:22, -1, -0.2, 23.7
2019/09/28 11:19:30, -1, -0.2, 23.7
2019/09/28 11:19:41, -1, -0.1, 23.7
2019/10/07 21:51:01,LLL ,LLL , 24.0
2019/10/07 21:52:10,LLL ,LLL , 24.2
2019/10/07 21:52:22,LLL ,LLL , 24.2
2019/10/07 21:52:32,LLL ,LLL , 24.2
2019/10/07 21:52:43,LLL ,LLL , 24.2
2019/10/12 11:11:40,LLL ,LLL , 23.7
2019/10/12 11:17:00,LLL ,LLL , 24.6
2019/11/16 19:59:06,LLL ,LLL , 24.9
2019/11/22 20:48:55,LLL ,LLL , 24.9
2019/11/22 20:58:37,LLL ,LLL , 25.1
▪▪ FORMAT ▪▪
NFC Well Known (0x01)
Defined by RFC 2141, RFC 3986
▪▪ TYPE ▪▪
T
▪▪ PAYLOAD (4888 bytes) ▪▪
0x02 0x65 0x6E 0x44 0x61 0x74 0x65 0x20 0x54 0x69 0x6D 0x65 0x2C 0x4F 0x65 0x63 0x68 0x73 0x6C 0x65 0x20 0x5B 0x64 0x65 0x67 0x5D 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x2C 0x42 0x72 0x69 0x78 0x20 0x5B 0x25 0x5D 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x2C 0x54 0x65 0x6D 0x70 0x20 0x5B 0x64 0x65 0x67 0x43 0x5D 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x30 0x39 0x2F 0x32 0x38 0x20 0x31 0x31 0x3A 0x31 0x38 0x3A 0x32 0x30 0x2C 0x20 0x20 0x20 0x20 0x20 0x20 0x2D 0x31 0x2C 0x20 0x20 0x20 0x20 0x2D 0x30 0x2E 0x32 0x2C 0x20 0x20 0x20 0x20 0x32 0x33 0x2E 0x37 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x30 0x39 0x2F 0x32 0x38 0x20 0x31 0x31 0x3A 0x31 0x39 0x3A 0x30 0x33 0x2C 0x20 0x20 0x20 0x20 0x20 0x20 0x2D 0x31 0x2C 0x20 0x20 0x20 0x20 0x2D 0x30 0x2E 0x32 0x2C 0x20 0x20 0x20 0x20 0x32 0x33 0x2E 0x37 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x30 0x39 0x2F 0x32 0x38 0x20 0x31 0x31 0x3A 0x31 0x39 0x3A 0x31 0x33 0x2C 0x20 0x20 0x20 0x20 0x20 0x20 0x2D 0x31 0x2C 0x20 0x20 0x20 0x20 0x2D 0x30 0x2E 0x32 0x2C 0x20 0x20 0x20 0x20 0x32 0x33 0x2E 0x37 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x30 0x39 0x2F 0x32 0x38 0x20 0x31 0x31 0x3A 0x31 0x39 0x3A 0x32 0x32 0x2C 0x20 0x20 0x20 0x20 0x20 0x20 0x2D 0x31 0x2C 0x20 0x20 0x20 0x20 0x2D 0x30 0x2E 0x32 0x2C 0x20 0x20 0x20 0x20 0x32 0x33 0x2E 0x37 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x30 0x39 0x2F 0x32 0x38 0x20 0x31 0x31 0x3A 0x31 0x39 0x3A 0x33 0x30 0x2C 0x20 0x20 0x20 0x20 0x20 0x20 0x2D 0x31 0x2C 0x20 0x20 0x20 0x20 0x2D 0x30 0x2E 0x32 0x2C 0x20 0x20 0x20 0x20 0x32 0x33 0x2E 0x37 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x30 0x39 0x2F 0x32 0x38 0x20 0x31 0x31 0x3A 0x31 0x39 0x3A 0x34 0x31 0x2C 0x20 0x20 0x20 0x20 0x20 0x20 0x2D 0x31 0x2C 0x20 0x20 0x20 0x20 0x2D 0x30 0x2E 0x31 0x2C 0x20 0x20 0x20 0x20 0x32 0x33 0x2E 0x37 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x31 0x30 0x2F 0x30 0x37 0x20 0x32 0x31 0x3A 0x35 0x31 0x3A 0x30 0x31 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x20 0x20 0x20 0x20 0x32 0x34 0x2E 0x30 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x31 0x30 0x2F 0x30 0x37 0x20 0x32 0x31 0x3A 0x35 0x32 0x3A 0x31 0x30 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x20 0x20 0x20 0x20 0x32 0x34 0x2E 0x32 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x31 0x30 0x2F 0x30 0x37 0x20 0x32 0x31 0x3A 0x35 0x32 0x3A 0x32 0x32 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x20 0x20 0x20 0x20 0x32 0x34 0x2E 0x32 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x31 0x30 0x2F 0x30 0x37 0x20 0x32 0x31 0x3A 0x35 0x32 0x3A 0x33 0x32 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x20 0x20 0x20 0x20 0x32 0x34 0x2E 0x32 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x31 0x30 0x2F 0x30 0x37 0x20 0x32 0x31 0x3A 0x35 0x32 0x3A 0x34 0x33 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x20 0x20 0x20 0x20 0x32 0x34 0x2E 0x32 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x31 0x30 0x2F 0x31 0x32 0x20 0x31 0x31 0x3A 0x31 0x31 0x3A 0x34 0x30 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x20 0x20 0x20 0x20 0x32 0x33 0x2E 0x37 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x31 0x30 0x2F 0x31 0x32 0x20 0x31 0x31 0x3A 0x31 0x37 0x3A 0x30 0x30 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x20 0x20 0x20 0x20 0x32 0x34 0x2E 0x36 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x31 0x31 0x2F 0x31 0x36 0x20 0x31 0x39 0x3A 0x35 0x39 0x3A 0x30 0x36 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x20 0x20 0x20 0x20 0x32 0x34 0x2E 0x39 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x31 0x31 0x2F 0x32 0x32 0x20 0x32 0x30 0x3A 0x34 0x38 0x3A 0x35 0x35 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x20 0x20 0x20 0x20 0x32 0x34 0x2E 0x39 0x0D 0x0A 0x32 0x30 0x31 0x39 0x2F 0x31 0x31 0x2F 0x32 0x32 0x20 0x32 0x30 0x3A 0x35 0x38 0x3A 0x33 0x37 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x4C 0x4C 0x4C 0x20 0x20 0x20 0x20 0x20 0x2C 0x20 0x20 0x20 0x20 0x32 0x35 0x2E 0x31 0x0D 0x0A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
▪▪ PAYLOAD (UTF8) ▪▪
enDate Time,Oechsle [deg] ,Brix [%] ,Temp [degC] 2019/09/28 11:18:20, -1, -0.2, 23.7 2019/09/28 11:19:03, -1, -0.2, 23.7 2019/09/28 11:19:13, -1, -0.2, 23.7 2019/09/28 11:19:22, -1, -0.2, 23.7 2019/09/28 11:19:30, -1, -0.2, 23.7 2019/09/28 11:19:41, -1, -0.1, 23.7 2019/10/07 21:51:01,LLL ,LLL , 24.0 2019/10/07 21:52:10,LLL ,LLL , 24.2 2019/10/07 21:52:22,LLL ,LLL , 24.2 2019/10/07 21:52:32,LLL ,LLL , 24.2 2019/10/07 21:52:43,LLL ,LLL , 24.2 2019/10/12 11:11:40,LLL ,LLL , 23.7 2019/10/12 11:17:00,LLL ,LLL , 24.6 2019/11/16 19:59:06,LLL ,LLL , 24.9 2019/11/22 20:48:55,LLL ,LLL , 24.9 2019/11/22 20:58:37,LLL ,LLL , 25.1
▪▪ PAYLOAD (ASCII) ▪▪
#include <Wire.h>
#include <PN532_I2C.h>
#include <PN532.h> // The following files are included in the libraries Installed
#include <NfcAdapter.h>
PN532_I2C pn532_i2c(Wire);
NfcAdapter nfc = NfcAdapter(pn532_i2c); // Indicates the Shield you are using
void setup(void) {
Serial.begin(9600);
Serial.println("NFC TAG READER"); // Header used when using the serial monitor
nfc.begin();
void loop(void) {
Serial.println("\nScan your NFC tag on the NFC Shield\n"); // Command so that you an others will know what to do
if (nfc.tagPresent())
NfcTag tag = nfc.read();
Serial.print("Nachricht: ");
tag.print();
Serial.println(tag.getTagType());
Serial.print("UID: ");Serial.println(tag.getUidString()); // Retrieves the Unique Identification from your tag
if (tag.hasNdefMessage()) // If your tag has a message
NdefMessage message = tag.getNdefMessage();
Serial.print("\nThis Message in this Tag is ");
Serial.print(message.getRecordCount());
Serial.print(" NFC Tag Record");
if (message.getRecordCount() != 1) {
Serial.print("s");
Serial.println(".");
// If you have more than 1 Message then it wil cycle through them
int recordCount = message.getRecordCount();
for (int i = 0; i < recordCount; i++)
Serial.print("\nNDEF Record ");Serial.println(i+1);
NdefRecord record = message.getRecord(i);
int payloadLength = record.getPayloadLength();
byte payload[payloadLength];
record.getPayload(payload);
String payloadAsString = ""; // Processes the message as a string vs as a HEX value
for (int c = 0; c < payloadLength; c++) {
payloadAsString += (char)payload[c];
Serial.print(" Information (as String): ");
Serial.println(payloadAsString);
String uid = record.getId();
if (uid != "") {
Serial.print(" ID: ");Serial.println(uid); // Prints the Unique Identification of the NFC Tag
delay(10000);
Nachricht: NFC Tag - NFC Forum Type 2
UID 02 84 66 6D 9E 27 FE
NDEF Message 1 record, 3 bytes
NDEF Record
TNF 0x0 Empty
Type Length 0x0 0
Payload Length 0x0 0
Type
Payload
Record is 3 bytes
NFC Forum Type 2
UID: 02 84 66 6D 9E 27 FE
This Message in this Tag is 1 NFC Tag Record.
NDEF Record 1
▪▪ DATA ▪▪
▪▪ FORMAT ▪▪
▪▪ TYPE ▪▪
T
#include <Wire.h>
void setup(void) {
Serial.begin(9600);
nfc.begin();
void loop(void) {
tag.print();
Serial.print("s");
if (uid != "") {
delay(10000);
NDEF Record
TNF 0x0 Empty
Type Length 0x0 0
Type
Payload
Record is 3 bytes
NFC Forum Type 2
NDEF Record 1
- MrBlue1234
Is there an update to this post?
Were you able to use the PN532 Library from Adafruit to read an NDEF message?
Thank you.
Thank you.
