Adafruit BNO055 Not Detetced,even I2C scanner shows nothing
by Chanddu on Mon Sep 16, 2019 8:56 am
Hi Adafruit,
Recently we got 3 Adafruit BNO055 sensors and tested the example scenes but its says Check the connections & Wiring but We checked & tried different connections & codes and followed the solutions provided by fellow coders in the similar threads(like changing the Versions,adding Pullups resistors to SCL,SDA etc) but unfortunately no Luck,Even I2C scanners shows nothing.Any help will be appreciated.
Thanks & Regards,
Chanddu.
I2C Scanner Result
Board Connections:-Vin to 5V, SCL to A5, SDA to A4, GND to GND
Chanddu
Re: Adafruit BNO055 Not Detetced,even I2C scanner shows noth
by dThirteen on Wed Sep 18, 2019 4:04 am
Are your header pins actually soldered in? If you have just pushed them through to the breadboard, you may have a bad connection.
dThirteen
