CLUE: Can't find example under Full_Board_Tests
by IraSch on Wed Feb 12, 2020 7:07 pm
Just upgraded to Arduino IDE 1.8.11, added the Board support, and installed the Arcada library (and it's dozen+ related libraries automagically) and the Sensor library (also many related libraries automagically).
Set the board type to CLUE, went to Examples, navigated down to Full_Board_Tests but don't see the CLUE example(s). There are 6 subitems under full_board_tests, but no CLUE example as shown in the documentation.
Did I miss something?
Thanks,
IraSch
Re: CLUE: Can't find example under Full_Board_Tests
by IraSch on Wed Feb 12, 2020 7:29 pm
I would like to know what I missed to not get the example, but in the interest of moving forward, I pulled the example .ino down from Github. When compiling, I get the following errors:
C:\Users\Ira\Documents\Arduino\libraries\Adafruit_Arcada_Library\Adafruit_Arcada.cpp: In member function 'bool Adafruit_Arcada_SPITFT::arcadaBegin()':
C:\Users\Ira\Documents\Arduino\libraries\Adafruit_Arcada_Library\Adafruit_Arcada.cpp:105:12: error: 'class Adafruit_NeoPixel' has no member named 'fill'
     pixels.fill(0);
Multiple libraries were found for "Adafruit_GFX.h"
 Used: C:\Users\Ira\Documents\Arduino\libraries\Adafruit_GFX_Library
 Not used: C:\Users\Ira\Documents\Arduino\libraries\ArducamSSD1306
 Not used: C:\Users\Ira\Documents\Arduino\libraries\ArducamSSD1306-master
exit status 1
Error compiling for board Adafruit CLUE.
IraSch
by jdelcamp11 on Wed Feb 12, 2020 7:33 pm
jdelcamp11
by IraSch on Wed Feb 12, 2020 9:00 pm
Looks like it isn't called "clue" in the list
I believe the link you sent is for something else. The instructions for the new CLUE board [url]file:///C:/Users/Ira/Downloads/adafruit-clue.pdf[/url] show an example called acada_clue_test
I was able to get the example, but still can't compile it without an error.
IraSch
by rfterry on Wed Feb 12, 2020 11:10 pm
Also can not find the arcada_clue_text file. I directly downloaded CLUE_TEST.UF2
rfterry
by rfterry on Wed Feb 12, 2020 11:12 pm
Also can not find the "arcada_clue_text" file. I directly downloaded and flashed CLUE_TEST.UF2. It seems to run all tests just fine. Out of the box my CLUE's right button failed to activate the two white LED's. CLUE_TEST.UF2 corrected that as well. Now I just need the source code to "start hacking".
rfterry
by IraSch on Thu Feb 13, 2020 10:57 am
I was able to find the arcada_clue_test file in Github: https://github.com/adafruit/Adafruit_Arcada
I had several problems getting it to compile, which seems to have traced back to the version of Adafruit NeoPixel I had installed, which was older.
I'm still not sure why the examples didn't install with the rest of the Arcada package.
On the other hand, I'm assuming that when a library package is installed, newer versions don't automatically overwrite older versions (in my case Adafruit NeoPixel). I did get about 30 warnings of Library Already Installed when I installed the Arcada and Sensor library packages. I guess I'm going to have to check each one to see which need updating.
IraSch
by jdelcamp11 on Thu Feb 13, 2020 11:26 am
Glad you found it. Hopefully things are working now.
jdelcamp11
