CLUE - APDS9960 proximity reading stops
by Aoyama_PROD on Thu Feb 13, 2020 9:35 am
*added the video on Twitter
https://twitter.com/AoyamaProd/status/1227951757994557441
APDS9660 proximity is not working once the proximity >= 51.
just writing as follows;
from adafruit_clue import clue
data = clue.simple_text_display(text_scale=3, colors=(clue.WHITE,))
data[0].text = "Proximity &"
data[1].text = "Gesture"
while True:
    alarm = False
    prox = clue.proximity
    ges = clue.gesture
    data[3].text = "Prox: {}".format(prox)
    data[5].text = "Gesture: {}".format(ges)
    data.show()
I'm using CircuitPython 5.0.0-beta.5 and adafruit-circuitpython-bundle-5.x-mpy-20200213.
Is it a know issue for CLUE or specific to my CLUE board?
Aoyama_PROD
Re: CLUE - APDS9960 proximity reading stops
by dastels on Thu Feb 13, 2020 11:21 am
I'm seeing the same behavior with the same CircuitPython and bundle.
I'll have a look inside.
dastels
by dastels on Thu Feb 13, 2020 11:36 am
The loop continues to run, but proximity just continues to return 51.
It's in the apds9960 library. Soimething to do with the gesture code.
Line 144 is:
self.gesture_proximity_threshold = 50
Change that to 60 and the prox freezes at 61. Hmmm.
dastels
by dastels on Thu Feb 13, 2020 11:46 am
A workaround.
Add this line just before the while True: loop
clue._sensor.gesture_proximity_threshold = 255
Gestures won't get triggered, but proximity will work.
dastels
by Aoyama_PROD on Fri Feb 14, 2020 8:23 pm
Great! Thank you so much for the investigation and the work around! I also get information from @anne_engineer that the APDS9660 library to be updated.
Aoyama_PROD
by shamurai on Sun Aug 09, 2020 3:37 pm
Just came across this same issue which is present in both CircuitPython 5.3.1 and CircuitPython 6.0.0-alpha.2.
Is there some other workaround besides "just don't use gesture and proximity in the same code"?
shamurai
by dastels on Mon Aug 31, 2020 11:00 am
Please don't hijack existing threads. Create new threads for your questions/issues.
dastels
