CLUE: Tone no longer works for Button A
by IraSch on Mon Feb 17, 2020 2:06 pm
Got my CLUE and started playing with it.
Right out of the box, Button A would cause a tone to be emitted (as expected) and Button B did nothing (which seems to be a common issue with whatever default program was installed).
I uploaded the Clue full_board_tests sketch and now Button B lights the white LEDs correctly, but Button A no longer sounds a tone. I opened up the serial monitor and Button A does show that it is getting pressed, but no tone sounds.
Any ideas why no sound?
Also, what library is responsible for tone()?
Thanks.
IraSch
Re: CLUE: Tone no longer works for Button A
by IraSch on Mon Feb 17, 2020 3:03 pm
After some research, it appears that the definition for ARCADA_AUDIO_OUT is being set to 0 for some reason in Adafruit_Arcada_Clue. h
According to the preliminary documentation, the tone/beeper is on D46.
If I change the 2 tone() function calls from tone(ARCADA_AUDIO_OUT, .... to tone(46, ...... then everything works as it should.
IraSch
