Question regarding Tmp36 Sensor
by desnotes on Sun Jul 04, 2010 11:53 am
I am trying to implement the TMP 36 temperature sensor and getting readings about 10 degrees C higher than they should be. I am running the sensor on 3.3 volts from an Arduino Duemilanove and am getting the "special indicator on pin 14 to measure the bandgap. Here are some typical readings:
RefReading (BANDGAP): 189
Supply Voltage: 5.69 (calculated from (1.05 * 1024) / refReading
TmpReading: 152 )analog reading from PIN 1)
TempVoltage: .84 volts (calculated from: (TmpReading * supplyVoltage) / 1024
TempC: 34.00 (calculated from: (TempVoltage - .5) * 100
The temperature in the room is a pretty steady 25 degrees C and is confirmed by a another sensor and a thermometer with humidity. Does anything stand out? I don't understand why the supply voltage reads so high when I am using the 3.3 volt pin. The Arduino is being powered by the USB line and thought that might be it.
Could it just be a bad sensor? Unfortunately I don't have an additional Tmp36 except for some SMD versions which I haven't soldered to a breakout board.
Any suggestions?
TIA,
desNotes
Tampa
desnotes
Re: Question regarding Tmp36 Sensor
by adafruit on Sun Jul 04, 2010 12:49 pm
dont use the bandgap, its inconsistant between arduinos, we have deleted that tutorial
refresh the page and use the new tutorial using the 3v ref
by desnotes on Sun Jul 04, 2010 1:33 pm
Thanks for the quick response. I will try it as soon as I get back home.
Thanks again,
desNotes
desnotes
by desnotes on Mon Jul 05, 2010 11:12 am
I tried it last night and still could not get the numbers in the ballpark when using the 3.3 volts pin. I switched over to 5 volt pin and assigned "aref_voltage" to 5 volts and it worked successfully. Not sure what I did to make the 3.3 volt pin not work but will step through process again later and see what I missed.
Thank you for the support,
desNotes
desnotes
