Bad TFT / washed-out BMPs on CLUE
by tlpada on Sat Mar 07, 2020 3:15 pm
The CLUE board I just received seems unable to display BMP files correctly.
When I try the CLUE Slideshow example, all 3 of the 'Blinka' BMPs are either partially or completely 'washed out'.
Blinka_240x240.bmp is completely washed out, Blinka_Love seems to have only one color present on a white/black background, and Blinka_Ouroboros is similarly a single color on a washed background.
Standard 240x240 BMPs from Adafruit's library examples are also washed out, e.g. the 'banana', 'avocado', 'cherries', etc.
avocado 240x240 bmp
I have other examples, all the 'fruit' and 'notification icon' BMPs are similarly entirely washed out or only bi-color or tri-color seeming.
Everything else about the CLUE board seems to work however.
Could the TFT be bad or something else?
Order #2266879-5982354693, ordered 2/28/20, received 3/4/20.
tlpada
Re: Bad TFT / washed-out BMPs on CLUE
by adafruit_support_carter on Tue Mar 10, 2020 7:12 pm
Can you try running the test program from here:
https://learn.adafruit.com/adafruit-clue/arduino-test
and see if the TFT appears normal with that.
You don't need to use Arduino. Just download the UF2 file, put the CLUE in bootloader mode, and drag the UF2 file over.
by tlpada on Tue Mar 10, 2020 9:27 pm
Ran test, looks normal AFAICT, attached. Pushing left and right buttons also made sound and light.
shot of CLUE running arduino test from bootloader mode
tlpada
by adafruit_support_carter on Wed Mar 11, 2020 2:02 pm
OK, that much at least looks normal.
You were following this guide?
https://learn.adafruit.com/adafruit-clue/clue-slideshow
How did you save the BMPs and copy them to your CLUE?
by tlpada on Wed Mar 11, 2020 3:06 pm
Yes, I downloaded and then copied over several BMPs -- first the 'Blinka' BMPs from Adafruit's site, then the Adafruit 'fruits' library (banana, avocado, berries etc.), then the Adafruit notification icons ('basecamp', 'slack') -- on linux and then copied to CIRCUITPY mount (and also using mu-edit, moving them around). Same result for all. I also checked the image properties for each one, to see if there were any differences, that they were all 240x240 etc. I also confirmed problem still exists after trying this arduino test; reloaded circuitpython, TFT still bad.
tlpada
by adafruit_support_carter on Wed Mar 11, 2020 4:46 pm
OK, let's try another color test independent of bitmaps files. Load this UF2 the same way as the other test:
clue_color_test.UF2
(142 KiB) Downloaded 5 times
Put the CLUE in bootloader mode and drag the UF2 file over. It's very simple, just prints colored rectangles on the screen, top row = red, green, blue, bottom row = cyan, yellow, magenta.
by tlpada on Wed Mar 11, 2020 7:45 pm
Done. Looks pretty right AFAICT. Still same problem, though, when I reloaded the circuitpython boot and ran "clue_slideshow.py".
running clue color test
tlpada
by adafruit_support_carter on Wed Mar 11, 2020 7:50 pm
Thanks for running that test. Agree, the display looks like it's working OK. So it seems like something is potentially mangling the BMP files somehow. CircuitPython is currently fairly limited in the BMP file formats it can support. Your PC can support many more, so can be tricky to verify the BMPs on the PC side.
It sounds like you are using linux on your PC?
by tlpada on Wed Mar 11, 2020 8:00 pm
Yes, using linux on the PC side.
Wouldn't 'sum' hashes on the files confirm that they're identical to those downloaded from Adafruit?
Here are sums I have on the Adafruit files I used:
$ sum *bmp
And then, here are the sums of the same images sitting on the CIRCUITPY 'filesystem' (albeit, it's still linux OS calculating the sums):
[tlp@localhost CIRCUITPY]$ sum *bmp
Also, FWIW, I also tried my own custom images -- regular photographs that I used GIMP to scale down to 240x240 BMPs. Exact same result -- washed out and/or monochrome images. They almost looked like 'negatives', so I also tried reversing the images. Same result.
tlpada
by adafruit_support_carter on Wed Mar 11, 2020 8:30 pm
Try wget'ing them:
wget https://cdn-learn.adafruit.com/assets/assets/000/088/500/original/adafruit_products_Blinka_240x240.bmp
wget https://cdn-learn.adafruit.com/assets/assets/000/088/501/original/adafruit_products_Blinka_Love_240x240.bmp
wget https://cdn-learn.adafruit.com/assets/assets/000/088/502/original/adafruit_products_Blinka_Ouroboros_240x240.bmp
I'm getting some slightly different results from sum:
$ sum *bmp
I just tested all those BMPs and they ran fine on a CLUE with slideshow.
by tlpada on Wed Mar 11, 2020 8:44 pm
Interesting, when I wget them, I get the sums that you show. And YET... running clue_sideshow.py again on them... it's the same broken result. 'Love' and 'Ouroboros' are monochrome (barely, faint purple on white), and the main 'Blinka_240x240' is completely washed out. In other words, same result on the TFT, exactly, as with the BMPs I used. This kind of makes sense, I think, as it seems that 'any' BMP fails, regardless if I had a different version of the adafruit ones; because it happens to every/any/random BMP I created and/or tested.
[tlp@localhost CIRCUITPY]$ pwd
/run/media/tlp/CIRCUITPY
[tlp@localhost CIRCUITPY]$ wget https://cdn-learn.adafruit.com/assets/a ... 40x240.bmp
--2020-03-11 20:32:38-- https://cdn-learn.adafruit.com/assets/a ... 40x240.bmp
Resolving cdn-learn.adafruit.com (cdn-learn.adafruit.com)... 104.20.39.240, 104.20.38.240, 2606:4700:10::6814:26f0, ...
Connecting to cdn-learn.adafruit.com (cdn-learn.adafruit.com)|104.20.39.240|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 115256 (113K) [image/bmp]
Saving to: ‘adafruit_products_Blinka_240x240.bmp’
adafruit_products_Blinka_240x240.bmp 100%[====================================================================>] 112.55K --.-KB/s in 0.07s
2020-03-11 20:32:41 (1.53 MB/s) - ‘adafruit_products_Blinka_240x240.bmp’ saved [115256/115256]
--2020-03-11 20:32:51-- https://cdn-learn.adafruit.com/assets/a ... 40x240.bmp
Resolving cdn-learn.adafruit.com (cdn-learn.adafruit.com)... 104.20.38.240, 104.20.39.240, 2606:4700:10::6814:27f0, ...
Connecting to cdn-learn.adafruit.com (cdn-learn.adafruit.com)|104.20.38.240|:443... connected.
Saving to: ‘adafruit_products_Blinka_Love_240x240.bmp’
adafruit_products_Blinka_Love_240x24 100%[====================================================================>] 112.55K --.-KB/s in 0.07s
2020-03-11 20:32:53 (1.49 MB/s) - ‘adafruit_products_Blinka_Love_240x240.bmp’ saved [115256/115256]
--2020-03-11 20:33:01-- https://cdn-learn.adafruit.com/assets/a ... 40x240.bmp
Saving to: ‘adafruit_products_Blinka_Ouroboros_240x240.bmp’
adafruit_products_Blinka_Ouroboros_2 100%[====================================================================>] 112.55K --.-KB/s in 0.08s
2020-03-11 20:33:03 (1.37 MB/s) - ‘adafruit_products_Blinka_Ouroboros_240x240.bmp’ saved [115256/115256]
tlpada
by adafruit_support_carter on Wed Mar 11, 2020 8:50 pm
Hmm. OK, try updating everything. Make sure you have latest firmware:
https://circuitpython.org/board/clue_nrf52840_express/
and libraries:
https://circuitpython.org/libraries
by tlpada on Wed Mar 11, 2020 9:40 pm
Done. Sadly same result with the images -- freshly WGET'd again. (I started by deleting *.* on the existing CLUE board, then remounting/overriding with fresh firmware, then the libraries, then the examples).
BTW, the firmware was the same version I was already using; I overwrote it nonetheless with a freshly downloaded copy ("adafruit-circuitpython-clue_nrf52840_express-en_US-5.0.0.uf2).
The only thing different than what I was running, is the bundle library version. Before, I was running "adafruit-circuitpython-bundle-5.x-mpy-20200306.zip." Now I downloaded "adafruit-circuitpython-bundle-5.x-mpy-20200311.zip" (311, I assume the date, is the only difference).
Do these directories and files look right? (these are from the new instance).
clue circuitpython root directory
clue circuitpython lib directory
tlpada
by adafruit_support_carter on Thu Mar 12, 2020 12:47 pm
Really weird issue. In theory, we should both be running the same hardware and firmware. But we can't recreate the issue on this side.
Can you make a zip of your entire CIRCUITPY folder and attach it here. You'll need to change the filename extension to get around the filter. Can just make it .txt or something and we can rename here.
by tlpada on Thu Mar 12, 2020 4:54 pm
Ok thanks, here you go, attached.
I also added the 'fruits' BMPs that fail to render similarly, from https://cdn-learn.adafruit.com/assets/a ... 1565633564.
CIRCUITPY.zip.txt
CLUE circuitpython image zip
(530.5 KiB) Downloaded 3 times
tlpada
