This is a software modification for my freshly released thermal camera project. It's an alternative PyBadge sketch that configures the camera to launch into a fever sensing mode, while preserving all the original camera functions. It consists of two files. One is the alternate source code for the PyBadge using Arduino programming and the Arcada library, the other is a header file containing sound data. Here's the modded PyBadge code.
ThermalImager_009e - Collect thermal image values from a MLX90640 sensor array,
display them as color-mapped pixels on a TFT screen,
include data capture to flash media, and a user configuration menu.
Written by Disciple using code from these sources.
Arcada and MLX90640 libraries from adafruit.com
Ver. 1 - Read temps, auto-range extremes, display gray squares on TFT
Ver. 2 - Add Ironbow color palette, low+center+high markers
Ver. 3 - Add crude BMP image write to SD
Ver. 4 - Attach interrupts to improve button response
Ver. 5 - Store BMPs to SD in an orderly manner, in folders
Ver. 6 - Port to Teensy 3.2, where the libraries used are suited
Ver. 7 - Port to Adafruit PyBadge using Arcada library. Use simulated data while awaiting hardware release
Ver. 8 - Convert menu to scrolling style and add settings for emissivity and frame rate, more if feasible.
Ver. 9 - Bring in the current Adafruit library and read a real sensor.
Ver. 9e - Add another preset temperature range for fever sensing, plus lower framerate, alarm palette, sound
#include <Adafruit_MLX90640.h>
#include "Adafruit_Arcada.h"
#include <Audio.h>
#include "sound.h" // "Pew" sound is here
Adafruit_MLX90640 mlx;
Adafruit_Arcada arcada;
AudioPlayMemory sound;
AudioOutputAnalogStereo audioOut;
AudioConnection c0(sound, 0, audioOut, 0);
#if !defined(USE_TINYUSB)
#warning "Compile with TinyUSB selected!"
#endif
File myFile;
float mlx90640To[768]; // Here we receive the float vals acquired from MLX90640
#define DE_BOUNCE 200
// Wait this many msec between button clicks
#define MENU_LEN 13
// Number of total available menu choices
#define MENU_ROWS 9
// Number of menu lines that can fit on screen
#define MENU_VPOS 6
#define GRAY_33 0x528A
#define BOTTOM_DIR "MLX90640"
#define DIR_FORMAT "/dir%05d"
#define BMP_FORMAT "/frm%05d.bmp"
#define CFG_FLNAME "/config.ini"
#define MAX_SERIAL 999
// Radiant fever alert values in Fahrenheit. Combine 'FEVER ALERT' range preset with 'HOT ALARM' palette.
// FEVER_SPAN defines the displayed temp range. Values higher than FEVER_THRESH will display alarm colors.
#define FEVER_THRESH 96.4
#define FEVER_SPAN 20.0
// BMP File Header, little end first, Photoshop ver.
const PROGMEM uint8_t BmpPSPHead[14] = {
0x42, 0x4D, // "BM" in hex
0x38, 0x09, 0x00, 0x00, // File size, 2360
0x00, 0x00, // reserved for app data 1
0x00, 0x00, // reserved for app data 2
0x36, 0x00, 0x00, 0x00 // Offset of first pixel, 54
// BMP 24-bit DIB Header, little end first, Photoshop ver.
const PROGMEM uint8_t DIBHeadPSP1[40] = {
0x28, 0x00, 0x00, 0x00, // Header size, 40
0x20, 0x00, 0x00, 0x00, // pixel width, 32
0x18, 0x00, 0x00, 0x00, // pixel height, 24
0x01, 0x00, // color planes, 1
0x18, 0x00, // bits per pixel, 24
0x00, 0x00, 0x00, 0x00, // Compression method, 0==none
0x00, 0x00, 0x00, 0x00, // Raw bitmap data size, dummy 0
0x12, 0x0B, 0x00, 0x00, // Pixels per meter H, 2834
0x12, 0x0B, 0x00, 0x00, // Pixels per meter V, 2834
0x00, 0x00, 0x00, 0x00, // Colors in palette, 0==default 2^n
0x00, 0x00, 0x00, 0x00 // Number of important colors, 0
// BMP file data, 2 byte padding
const PROGMEM uint8_t PSPpad[2] = {0x00, 0x00};
//Byte arrays of bitmapped icons, 16 x 12 px:
const PROGMEM uint8_t battIcon[] = {
0x0f, 0x00, 0x3f, 0xc0, 0x20, 0x40, 0x20, 0x40, 0x20, 0x40, 0x20, 0x40,
0x20, 0x40, 0x20, 0x40, 0x20, 0x40, 0x20, 0x40, 0x20, 0x40, 0x3f, 0xc0};
const PROGMEM uint8_t camIcon[] = {
0x01, 0xe0, 0x61, 0x20, 0xff, 0xf0, 0x80, 0x10, 0x86, 0x10, 0x89, 0x10,
0x90, 0x90, 0x90, 0x90, 0x89, 0x10, 0x86, 0x10, 0x80, 0x10, 0xff, 0xf0};
const PROGMEM uint8_t SDicon[] = {
0x0f, 0xe0, 0x1f, 0xe0, 0x3c, 0x60, 0x78, 0x60, 0x70, 0x60, 0x60, 0x60,
0x60, 0x60, 0x60, 0x60, 0x6f, 0x60, 0x60, 0x60, 0x7f, 0xe0, 0x7f, 0xe0};
const PROGMEM uint8_t snowIcon[] = {
0x15, 0x00, 0x4E, 0x40, 0xC4, 0x60, 0x75, 0xC0, 0x9F, 0x20, 0x0E, 0x00,
0x0E, 0x00, 0x9F, 0x20, 0x75, 0xC0, 0xC4, 0x60, 0x4E, 0x40, 0x15, 0x00};
uint8_t pixelArray[2304]; // BMP image body, 32 pixels * 24 rows * 3 bytes
// Some global values that several functions will use, including
// 5 floats to append to the BMP pixel data:
// coldest pixel, coldest color, center temp, hottest color, hottest pixel
float sneakFloats[5] = {3.1415926, 0.0, -11.7, 98.6, -12.34}; // Test values that get overwritten
uint16_t highAddr = 0, lowAddr = 0; // Append the pixel addresses, too
uint16_t backColor, lowPixel, highPixel, buttonRfunc = 1,
emissivity = 95, frameRate = 3,
thermRange = 6, paletteNum = 3, colorPal[256], // Array for color palettes
nextDirIndex = 0, nextBMPindex = 0, nextBMPsequence = 1; // These keep count of SD files and dirs, 0==error
uint32_t deBounce = 0, buttonBits = 0;
boolean mirrorFlag = false, celsiusFlag = false, markersOn = true,
screenDim = false, smoothing = false, alarmBeep = true,
showLastCap = false, save1frame = false,
recordingInProg = false, buttonActive = false;
float battAverage = 0.0, colorLow = 0.0, colorHigh = 100.0; // Values for managing color range
volatile boolean clickFlagMenu = false, clickFlagSelect = false; // Volatiles for timer callback handling
void setup()
if (!arcada.arcadaBegin()) { // Start TFT and fill with black
// Serial.print("Failed to begin");
while (1);
arcada.filesysBeginMSD(); // Set up SD or QSPI flash as an external USB drive
arcada.displayBegin(); // Activate TFT screen
arcada.display->setRotation(1); // wide orientation
arcada.display->setTextWrap(false);
arcada.setBacklight(255); // Turn on backlight
battAverage = arcada.readBatterySensor();
Serial.begin(115200);
// while(!Serial); // Wait for user to open terminal
Serial.println("MLX90640 IR Array Example");
if(arcada.filesysBegin()){ // Initialize flash storage, begin setting up indices for saving BMPs
if(!arcada.exists(BOTTOM_DIR)) { // Is base "MLX90640" directory absent?
if(arcada.mkdir(BOTTOM_DIR)) // Can it be added?
nextDirIndex = nextBMPindex = 1; // Success, prepare to store numbered files & dirs
} else { // "MLX90640" directory exists, can we add files | directories?
// Get the number of the next unused serial directory path
nextDirIndex = availableFileNumber(1, BOTTOM_DIR + String(DIR_FORMAT));
// and the next unused serial BMP name
nextBMPindex = availableFileNumber(1, BOTTOM_DIR + String(BMP_FORMAT));
} // By now each global index variable is either 0 (no nums available), or the next unclaimed serial num
if(!mlx.begin(MLX90640_I2CADDR_DEFAULT, &Wire)) {
Serial.println("MLX90640 not found!");
arcada.haltBox("MLX90640 not found!");
while(1)
delay(10); // Halt here
Serial.println("Found Adafruit MLX90640");
Serial.print("Serial number: ");
Serial.print(mlx.serialNumber[0], HEX);
Serial.print(mlx.serialNumber[1], HEX);
Serial.println(mlx.serialNumber[2], HEX);
//mlx.setMode(MLX90640_INTERLEAVED);
mlx.setMode(MLX90640_CHESS);
mlx.setResolution(MLX90640_ADC_18BIT);
switch(frameRate) {
case 0: mlx.setRefreshRate(MLX90640_0_5_HZ); break; // 6 frame rates, 0.5 to 16 FPS in powers of 2
case 1: mlx.setRefreshRate(MLX90640_1_HZ); break;
case 2: mlx.setRefreshRate(MLX90640_2_HZ); break;
case 3: mlx.setRefreshRate(MLX90640_4_HZ); break;
case 4: mlx.setRefreshRate(MLX90640_8_HZ); break;
default: mlx.setRefreshRate(MLX90640_16_HZ); break;
Wire.setClock(1000000); // max 1 MHz
for(int counter01 = 0; counter01 < 2304; ++counter01)
pixelArray[counter01] = counter01 / 9; // Initialize BMP pixel buffer with a gradient
loadPalette(paletteNum); // Load palette
backColor = GRAY_33; // 33% gray for BG
setBackdrop(backColor, buttonRfunc); // Current BG, current button labels
setColorRange(thermRange);
// Audio initialization
AudioMemory(10);
arcada.enableSpeaker(true);
arcada.setVolume(255);
arcada.timerCallback(50, buttonCatcher); // Assign a 50Hz callback function to catch button presses
void loop()
static uint32_t frameCounter = 0;
float scaledPix, highPix, lowPix;
uint16_t markColor;
// Show the battery level indicator, 3.7V to 3.3V represented by a 7 segment bar
battAverage = battAverage * 0.95 + arcada.readBatterySensor() * 0.05; // *Gradually* track battery level
highPix = (int)constrain((battAverage - 3.3) * 15.0, 0.0, 6.0) + 1; // Scale it to a 7-segment bar
markColor = highPix > 2 ? 0x07E0 : 0xFFE0; // Is the battery level bar green or yellow?
markColor = highPix > 1 ? markColor : 0xF800; // ...or even red?
arcada.display->fillRect(146, 2, 12, 12, backColor); // Erase old battery icon
arcada.display->drawBitmap(146, 2, battIcon, 16, 12, 0xC618); // Redraw gray battery icon
arcada.display->fillRect(150, 12 - highPix, 4, highPix, markColor); // Add the level bar
// Fetch 768 fresh temperature values from the MLX90640
arcada.display->drawBitmap(146, 18, camIcon, 16, 12, 0xF400); // Show orange camera icon during I2C acquisition
if(mlx.getFrame(mlx90640To) != 0) {
Serial.println("Failed");
return;
arcada.display->fillRect(146, 18, 12, 12, backColor); // Acquisition done, erase camera icon
// First pass: Find hottest and coldest pixels
highAddr = lowAddr = 0;
highPix = lowPix = mlx90640To[highAddr];
for (int x = 1 ; x < 768 ; x++) { // Compare every pixel
if(mlx90640To[x] > highPix) { // Hotter pixel found?
highPix = mlx90640To[x]; // Record its values
highAddr = x;
if(mlx90640To[x] < lowPix) { // Colder pixel found?
lowPix = mlx90640To[x]; // Likewise
lowAddr = x;
if(thermRange == 0) { // Are the colors set to auto-range?
colorLow = lowPix; // Then high and low color values get updated
colorHigh = highPix;
sneakFloats[0] = lowPix; // Retain these five temperature values
sneakFloats[1] = colorLow; // to append to the BMP file, if any
sneakFloats[2] = mlx90640To[400];
sneakFloats[3] = colorHigh;
sneakFloats[4] = highPix;
// Second pass: Scale the float values down to 8-bit and plot colormapped pixels
if(mirrorFlag) { // Mirrored display (selfie mode)?
for(int y = 0; y < 24; ++y) { // Rows count from bottom up
for(int x = 0 ; x < 32 ; x++) {
scaledPix = constrain((mlx90640To[32 * y + x] - colorLow) / (colorHigh - colorLow) * 255.9, 0.0, 255.0);
pixelArray[3 * (32 * y + x)] = (uint8_t)scaledPix; // Store as a byte in BMP buffer
arcada.display->fillRect(140 - x * 4, 92 - y * 4, 4, 4, colorPal[(uint16_t)scaledPix]); // Filled rectangles, bottom up
} else { // Not mirrored
arcada.display->fillRect(16 + x * 4, 92 - y * 4, 4, 4, colorPal[(uint16_t)scaledPix]);
// Play a sound effect if hottest temperature is over the fever threshold
if(thermRange == 6 && paletteNum == 3 && (highPix * 1.8 + 32.0 > FEVER_THRESH) && alarmBeep) {
digitalWrite(ARCADA_SPEAKER_ENABLE, HIGH); // Speaker on
sound.play(pew); // Start the sound
if(!sound.isPlaying()) // If end of "pew!" sound reached...
digitalWrite(ARCADA_SPEAKER_ENABLE, LOW); // Speaker off
// Post pass: Screen print the lowest, center, and highest temperatures
arcada.display->fillRect( 0, 96, 53, 12, colorPal[0]); // Contrasting mini BGs for cold temp
arcada.display->fillRect(107, 96, 53, 12, colorPal[255]); // and for hot temperature texts
scaledPix = constrain((mlx90640To[400] - colorLow) / (colorHigh - colorLow) * 255.9, 0.0, 255.0);
arcada.display->fillRect(53, 96, 54, 12, colorPal[(uint16_t)scaledPix]); // Color coded mini BG for center temp
arcada.display->setTextSize(1);
arcada.display->setCursor(10, 99);
arcada.display->setTextColor(0xFFFF ^ colorPal[0]); // Contrasting text color for coldest value
arcada.display->print(celsiusFlag ? lowPix : lowPix * 1.8 + 32.0); // Print Celsius or Fahrenheit
arcada.display->setCursor(120, 99);
arcada.display->setTextColor(0xFFFF ^ colorPal[255]); // Contrast text for hottest value
arcada.display->print(celsiusFlag ? highPix : highPix * 1.8 + 32.0); // Print Celsius or Fahrenheit
arcada.display->setCursor(65, 99);
if((mlx90640To[400] < (colorLow + colorHigh) * 0.5) == (paletteNum < 3))
arcada.display->setTextColor(0xFFFF); // A contrasting text color for center temp
else
arcada.display->setTextColor(0x0000);
arcada.display->print(celsiusFlag ? mlx90640To[400] : mlx90640To[400] * 1.8 + 32.0); // Pixel 12 * 32 + 16
markColor = 0x0600; // Deep green color to draw onscreen cross markers
if(markersOn) { // Show markers?
if(mirrorFlag) { // ...over a mirrored display?
arcada.display->drawFastHLine(156 - (( lowAddr % 32) * 4 + 16), 93 - 4 * ( lowAddr / 32), 4, markColor); // Color crosses mark cold pixel,
arcada.display->drawFastVLine(159 - (( lowAddr % 32) * 4 + 17), 92 - 4 * ( lowAddr / 32), 4, markColor);
arcada.display->drawFastHLine(156 - ((highAddr % 32) * 4 + 16), 93 - 4 * (highAddr / 32), 4, markColor); // hot pixel,
arcada.display->drawFastVLine(159 - ((highAddr % 32) * 4 + 17), 92 - 4 * (highAddr / 32), 4, markColor);
arcada.display->drawFastHLine(76, 45, 4, markColor); // and center pixel
arcada.display->drawFastVLine(78, 44, 4, markColor);
arcada.display->drawFastHLine(( lowAddr % 32) * 4 + 16, 93 - 4 * ( lowAddr / 32), 4, markColor); // Color crosses mark cold pixel,
arcada.display->drawFastVLine(( lowAddr % 32) * 4 + 17, 92 - 4 * ( lowAddr / 32), 4, markColor);
arcada.display->drawFastHLine((highAddr % 32) * 4 + 16, 93 - 4 * (highAddr / 32), 4, markColor); // hot pixel,
arcada.display->drawFastVLine((highAddr % 32) * 4 + 17, 92 - 4 * (highAddr / 32), 4, markColor);
arcada.display->drawFastHLine(80, 45, 4, markColor); // and center pixel
arcada.display->drawFastVLine(81, 44, 4, markColor);
// Print the frame count on the left sidebar
arcada.display->setRotation(0); // Vertical printing
arcada.display->setCursor(48, 4);
arcada.display->setTextColor(0xFFFF, backColor); // White text, current BG
arcada.display->print("FRM ");
arcada.display->print(++frameCounter);
arcada.display->setRotation(1); // Back to horizontal
// Handle any button presses
if(!buttonActive && clickFlagMenu) { // Was B:MENU button pressed?
buttonActive = true; // Set button flag
deBounce = millis() + DE_BOUNCE; // and start debounce timer
menuLoop(backColor); // Execute menu routine until finished
clickFlagSelect = recordingInProg = false; // Clear unneeded flags
setBackdrop(backColor, buttonRfunc); // Repaint current BG & button labels
if(!buttonActive && clickFlagSelect) { // Was the A button pressed?
if(buttonRfunc == 0) { // Freeze requested?
arcada.display->drawBitmap(146, 48, snowIcon, 16, 12, 0xC61F); // Freeze icon on
while(buttonBits & ARCADA_BUTTONMASK_A) // Naive freeze: loop until button released
delay(10); // Short pause
deBounce = millis() + DE_BOUNCE; // Restart debounce timer
arcada.display->fillRect(146, 48, 12, 12, backColor); // Freeze icon off
} else if(buttonRfunc == 1) { // Capture requested?
if((nextBMPindex = availableFileNumber(nextBMPindex, BOTTOM_DIR + String(BMP_FORMAT))) != 0) { // Serialized BMP filename available?
save1frame = true; // Set the flag to save a BMP
arcada.display->fillRect(0, 96, 160, 12, 0x0600); // Display a green strip
arcada.display->setTextColor(0xFFFF); // with white capture message text
arcada.display->setCursor(16, 99);
arcada.display->print("Saving frame ");
arcada.display->print(nextBMPindex);
} else { // Begin or halt recording a sequence of BMP files
if(!recordingInProg) { // "A:START RECORDING" was pressed
if((nextDirIndex = availableFileNumber(nextDirIndex, BOTTOM_DIR + String(DIR_FORMAT))) != 0) { // Serialized directory name available?
// Make the directory
if(newDirectory()) { // Success in making a new sequence directory?
recordingInProg = true; // Set the flag for saving BMP files
nextBMPsequence = 1; // ...numbered starting with 00001
setBackdrop(backColor, 3); // Show "A:STOP RECORDING" label
} else // Couldn't make the new directory, so
nextDirIndex = 0; // disable further sequences
} else { // "A:STOP RECORDING" was pressed
setBackdrop(backColor, 2); // Clear "A:STOP RECORDING" label
// Saving any BMP images to flash media happens here
if(save1frame || recordingInProg) { // Write a BMP file to SD?
arcada.display->drawBitmap(146, 32, SDicon, 16, 12, 0x07E0); // Flash storage activity icon on
prepForSave(); // Save to flash. Use global values for parameters
nextBMPsequence += recordingInProg ? 1 : 0; // If recording a series, increment frame count
save1frame = false; // If one frame saved, clear the flag afterwards
arcada.display->fillRect(146, 32, 12, 12, backColor); // Flash storage activity icon off
if(showLastCap) { // Redisplay the last BMP saved?
recallLastBMP(backColor); // Redisplay last bitmap from buffer until finished
showLastCap = false;
// Here we protect against button bounces while the function loops
if(buttonActive && millis() > deBounce && (buttonBits
& (ARCADA_BUTTONMASK_B | ARCADA_BUTTONMASK_A)) == 0) // Has de-bounce wait expired & all buttons released?
buttonActive = false; // Clear flag to allow another button press
clickFlagMenu = clickFlagSelect = false; // End of the loop, clear all interrupt flags
// Compute and fill an array with 256 16-bit color values
void loadPalette(uint16_t palNumber) {
uint16_t x, y;
float fleX, fleK;
switch(palNumber) {
case 1: // Compute ironbow palette
for(x = 0; x < 256; ++x) {
fleX = (float)x / 255.0;
// fleK = 65535.9 * (1.02 - (fleX - 0.72) * (fleX - 0.72) * 1.96);
// fleK = (fleK > 65535.0) || (fleX > 0.75) ? 65535.0 : fleK; // Truncate red curve
fleK = 63487.0 * (1.02 - (fleX - 0.72) * (fleX - 0.72) * 1.96);
fleK = (fleK > 63487.0) || (fleX > 0.75) ? 63487.0 : fleK; // Truncate red curve
colorPal[x] = (uint16_t)fleK & 0xF800; // Top 5 bits define red
// fleK = fleX * fleX * 2047.9;
fleK = fleX * fleX * 2015.0;
colorPal[x] += (uint16_t)fleK & 0x07E0; // Middle 6 bits define green
// fleK = 31.9 * (14.0 * (fleX * fleX * fleX) - 20.0 * (fleX * fleX) + 7.0 * fleX);
fleK = 30.9 * (14.0 * (fleX * fleX * fleX) - 20.0 * (fleX * fleX) + 7.0 * fleX);
fleK = fleK < 0.0 ? 0.0 : fleK; // Truncate blue curve
colorPal[x] += (uint16_t)fleK & 0x001F; // Bottom 5 bits define blue
break;
case 2: // Compute quadratic "firebow" palette
// fleK = 65535.9 * (1.00 - (fleX - 1.0) * (fleX - 1.0));
fleK = 63487.0 * (1.00 - (fleX - 1.0) * (fleX - 1.0));
// fleK = fleX < 0.25 ? 0.0 : (fleX - 0.25) * 1.3333 * 2047.9;
fleK = fleX < 0.25 ? 0.0 : (fleX - 0.25) * 1.3333 * 2015.0;
// fleK = fleX < 0.5 ? 0.0 : (fleX - 0.5) * (fleX - 0.5) * 127.9;
fleK = fleX < 0.5 ? 0.0 : (fleX - 0.5) * (fleX - 0.5) * 123.0;
break;
case 3: // Compute "alarm" palette
fleK = 65535.9 * (fleX < 0.875 ? 1.00 - (fleX * 1.1428) : 1.0);
fleK = 2047.9 * (fleX < 0.875 ? 1.00 - (fleX * 1.1428) : (fleX - 0.875) * 8.0);
fleK = 31.9 * (fleX < 0.875 ? 1.00 - (fleX * 1.1428) : 0.0);
break;
case 4: // Compute negative gray palette, black hot
colorPal[255 - x] = (((uint16_t)x << 8) & 0xF800) + (((uint16_t)x << 3) & 0x07E0) + (((uint16_t)x >> 3) & 0x001F);
break;
default: // Compute gray palette, white hot
colorPal[x] = (((uint16_t)x << 8) & 0xF800) + (((uint16_t)x << 3) & 0x07E0) + (((uint16_t)x >> 3) & 0x001F);
break;
void setColorRange(int presetIndex) { // Set coldest/hottest values in color range
switch(presetIndex) {
case 1: // Standard range, from FLIR document: 50F to 90F
colorLow = 10.0;
colorHigh = 32.22;
break;
case 2: // Cool/warm range, for detecting mammals outdoors
colorLow = 5.0;
colorHigh = 32.0;
break;
case 3: // Warm/warmer range, for detecting mammals indoors
colorLow = 20.0;
colorHigh = 32.0;
break;
case 4: // Hot spots, is anything hotter than it ought to be?
colorLow = 20.0;
colorHigh = 50.0;
break;
case 5: // Fire & ice, extreme temperatures only!
colorLow = -10.0;
colorHigh = 200.0;
break;
case 6: // Fever alert, a scale with 'hot alarm' colors ceneterd at a preset fever threshold
colorLow = ((FEVER_THRESH - FEVER_SPAN * 0.875) - 32.0) / 1.8;
colorHigh = ((FEVER_THRESH + FEVER_SPAN * 0.125) - 32.0) / 1.8;
break;
default: // Default is autorange, so these values will change with every frame
colorLow = 0.0;
colorHigh = 100.0;
break;
// Draw the stationary screen elements behind the live camera window
void setBackdrop(uint16_t bgColor, uint16_t buttonFunc) {
arcada.display->fillScreen(bgColor);
for(int x = 0; x < 160; ++x) // Paint current palette across bottom
arcada.display->drawFastVLine(x, 110, 6, colorPal[map(x, 0, 159, 0, 255)]);
arcada.display->setCursor(16, 120);
arcada.display->setTextColor(0xFFFF, bgColor); // White text, current BG for button labels
switch(buttonFunc) {
case 0:
arcada.display->print("B:MENU A:FREEZE");
break;
case 1:
arcada.display->print("B:MENU ");
if(nextBMPindex == 0) // No room to store a BMP in flash media?
arcada.display->setTextColor(GRAY_33 >> 1); // Grayed button label
arcada.display->print("A:CAPTURE");
break;
case 2:
if(nextDirIndex == 0) // Has flash storage no room for a new directory?
arcada.display->print("A:START RECORD");
break;
case 3:
arcada.display->setTextColor(0xFFFF, 0xF800); // White text, red BG recording indicator
arcada.display->print("A:STOP RECORD");
break;
case 4:
arcada.display->print(" A:EXIT"); // Use for bitmap redisplay only
break;
void prepForSave() {
for(int x = 0; x < 768; ++x)
pixelArray[3 * x + 2] = pixelArray[3 * x + 1] = pixelArray[3 * x]; // Copy each blue byte into R & G for 256 grays in 24 bits
if(!writeBMP()) { // Did BMP write to flash fail?
arcada.display->fillRect(0, 96, 160, 12, 0xF800); // Red error signal
arcada.display->setTextColor(0xFFFF); // with white text
arcada.display->setCursor(20, 99);
arcada.display->print("Storage error!");
boolean newDirectory() { // Create a subdirectory, converting the name between char arrays and string objects
char fileArray[64];
String fullPath;
sprintf(fileArray, DIR_FORMAT, nextDirIndex); // Generate subdirectory name
fullPath = BOTTOM_DIR + String(fileArray); // Make a filepath out of it, then
return arcada.mkdir(fullPath.c_str()); // try to make a real subdirectory from it
// Here we write the actual bytes of a BMP file (plus extras) to flash media
boolean writeBMP() {
uint16_t counter1, shiftedFloats[14]; // A buffer for the appended floats and uint16_t's
uint32_t timeStamp;
float shiftAssist;
char fileArray[64];
String fullPath;
// First, figure out a name and path for our new BMP
fullPath = BOTTOM_DIR; // Build a filepath starting with the base subdirectory
if(buttonRfunc == 2) { // BMP sequence recording in progress?
fullPath += String(fileArray); // Add it to the path
sprintf(fileArray, BMP_FORMAT, nextBMPsequence); // Generate a sequential filename
fullPath += String(fileArray); // Complete the filepath string
} else { // Not a sequence, solitary BMP file
sprintf(fileArray, BMP_FORMAT, nextBMPindex); // Generate a serial filename
myFile = arcada.open(fullPath.c_str(), FILE_WRITE); // Only one file can be open at a time
if(myFile) { // If the file opened okay, write to it:
myFile.write(BmpPSPHead, 14); // BMP header 1
myFile.write(DIBHeadPSP1, 40); // BMP header 2
myFile.write(pixelArray, 2304); // Array of 768 BGR byte triples
myFile.write(PSPpad, 2); // Pad with 2 zeros 'cause Photoshop does it.
// My BMP hack - append 5 fixed-point temperature values as 40 extra bytes
for(counter1 = 0; counter1 < 5; ++counter1) { // Shift 5 floats
shiftAssist = sneakFloats[counter1] + 1000.0; // Offset MLX90640 temps to positive
shiftedFloats[counter1 * 2] = (uint16_t)shiftAssist;
shiftAssist = (shiftAssist - (float)shiftedFloats[counter1 * 2]) * 49152.0; // Scale up fraction
shiftedFloats[counter1 * 2 + 1] = (uint16_t)shiftAssist;
shiftedFloats[10] = lowAddr; // Two more appended numbers, the 2 extreme pixel addresses
shiftedFloats[11] = highAddr;
timeStamp = millis(); // Recycle this variable to append a time stamp
lowAddr = timeStamp & 0xFFFF;
highAddr = timeStamp >> 16;
shiftedFloats[12] = lowAddr;
shiftedFloats[13] = highAddr;
myFile.write(shiftedFloats, 28); // Write appended uint16_t's
myFile.close();
return true;
} else { // The file didn't open, return error
return false;
void recallLastBMP(uint16_t bgColor) { // Display 8-bit values left in buffer from the last BMP save
int counter1, counter2;
boolean exitFlag = false;
setBackdrop(bgColor, 4); // Clear screen, just a color palette & "A:EXIT" in the BG
for(int counter1 = 0; counter1 < 24; ++counter1) { // Redraw using leftover red byte values, not yet overwritten
for(int counter2 = 0 ; counter2 < 32 ; ++counter2) {
arcada.display->fillRect(16 + counter2 * 4, 92 - counter1 * 4, 4, 4,
colorPal[(uint16_t)pixelArray[3 * (32 * counter1 + counter2) + 2]]);
while(!exitFlag) { // Loop here until exit button
if(!buttonActive && (buttonBits & ARCADA_BUTTONMASK_A)) { // "A:EXIT" button freshly pressed?
exitFlag = true;
&& (buttonBits & (ARCADA_BUTTONMASK_A | ARCADA_BUTTONMASK_B)) == 0) // Has de-bounce wait expired & all buttons released?
uint16_t availableFileNumber(uint16_t startNumber, String formatBase) { // Find unclaimed serial number for file series
uint16_t counter1;
char nameArray[80];
for(counter1 = startNumber; counter1 % MAX_SERIAL != 0; ++counter1) { // Start counting
sprintf(nameArray, formatBase.c_str(), counter1); // Generate a serialized filename
if(!arcada.exists(nameArray)) // If it doesn't already exist
return counter1; // return the number as available
return 0; // Loop finished, no free number found, return fail
boolean menuLoop(uint16_t bgColor) { // Lay out a menu screen, interact to change values
int counter1 = 0, scrollPosition = 0;
boolean exitFlag = false, settingsChanged = false;
uint32_t menuButtons;
arcada.display->fillRect(0, 12 * (counter1 + scrollPosition) + MENU_VPOS - 2, 160, 12, 0x0000); // Black stripe cursor on menu
arcada.display->setTextColor(0xFFFF); // White text
arcada.display->setCursor(16, 120); // at screen bottom
arcada.display->print("B:ADVANCE A:CHANGE"); // for button labels
for(counter1 = 0; counter1 < MENU_ROWS; ++counter1) { // Display menu texts
menuLines(counter1, scrollPosition);
counter1 = 0;
while(!exitFlag) { // Loop until exit is activated
if(!buttonActive && (buttonBits & ARCADA_BUTTONMASK_B)) { // Fresh press of B:ADVANCE button?
deBounce = millis() + DE_BOUNCE; // and start debounce timer.
arcada.display->fillRect(0, 12 * (counter1 - scrollPosition) + MENU_VPOS - 2, 160, 12, bgColor); // Erase cursor & text
menuLines(counter1, scrollPosition); // Refresh menu text line
counter1 = (counter1 + 1) % MENU_LEN; // Advance menu counter
if(counter1 == 0) { // Have we cycled around to the menu top?
scrollPosition = 0;
for(int counter2 = 0; counter2 < MENU_ROWS; ++counter2) { // Redisplay all menu texts
arcada.display->fillRect(0, 12 * counter2 + MENU_VPOS - 2, 160, 12, bgColor); // Erase old text
menuLines(counter2 + scrollPosition, scrollPosition); // Redraw each text line
} else if((counter1 + 1 < MENU_LEN) && (counter1 - scrollPosition == MENU_ROWS - 1)) { // Should we scroll down 1 menu line?
++scrollPosition;
arcada.display->fillRect(0, 12 * (counter1 - scrollPosition) + MENU_VPOS - 2, 160, 12, 0x0000); // New black cursor
menuLines(counter1, scrollPosition); // Refresh text line
deBounce = millis() + DE_BOUNCE; // Restart debounce timer, just for safety
if(!buttonActive && (buttonBits & ARCADA_BUTTONMASK_A)) { // Fresh press of A:CHANGE button?
switch(counter1) { // Change whichever setting is currently hilighted
case 0:
showLastCap = true; // Set flag to display the last frame captured to SD
exitFlag = true; // and exit
break;
case 1:
celsiusFlag = !celsiusFlag; // Toggle Celsius/Fahrenheit
break;
case 2:
buttonRfunc = (buttonRfunc + 1) % 3; // Step through button functions
break;
case 3:
loadPalette(paletteNum = (paletteNum + 1) % 5); // Step through various color palettes
break;
case 4:
thermRange = (thermRange + 1) % 7; // Step through various temp range presets
break;
case 5:
markersOn = !markersOn; // Toggle hot/cold marker visibility
break;
case 6:
mirrorFlag = !mirrorFlag; // Toggle mirrored display
break;
case 7:
switch(frameRate = (frameRate + 1) % 6) { // 6 frame rates, 0.5 to 16 in powers of 2
break;
case 8:
emissivity = (emissivity + 90) % 100; // Step from 95% to 5% by -10%
break;
case 9:
smoothing = !smoothing; // Toggle pixel smoothing
break;
case 10:
arcada.setBacklight((screenDim = !screenDim) ? 64 : 255); // Change backlight LED
break;
case 11:
alarmBeep = !alarmBeep; // Toggle fever alert sound effect
break;
default:
exitFlag = true;
break;
if((counter1 > 0) && (counter1 < MENU_LEN - 1)) // Was any setting just changed?
settingsChanged = true;
arcada.display->fillRect(0, 12 * (counter1 - scrollPosition) + MENU_VPOS - 2, 160, 12, 0x0000); // Erase hilit menu line
menuLines(counter1, scrollPosition); // Retype hilit menu line
return(settingsChanged);
void menuLines(int lineNumber, int scrollPos) { // Screen print a single line in the settings menu
arcada.display->setCursor(10, 12 * (lineNumber - scrollPos) + MENU_VPOS); // Menu lines 12 pixels apart
if(lineNumber - scrollPos == 0 && scrollPos > 0) { // Are any menu lines scrolled off screen top?
arcada.display->print(" ^"); // Print a small up arrow indicator
} else if(lineNumber - scrollPos == 8 && lineNumber + 1 < MENU_LEN) { // How about off the bottom?
arcada.display->print(" v"); // Print a small down arrow indicator... yeah, it's a v
} else {
switch(lineNumber) {
case 0:
arcada.display->print(" Display last capture");
break;
case 1:
arcada.display->print(" Scale - ");
arcada.display->print(celsiusFlag ? "CELSIUS" : "FAHRENHEIT");
break;
case 2:
arcada.display->print(" Rt button - ");
switch(buttonRfunc) {
case 1:
arcada.display->print("CAPTURE"); break;
case 2:
arcada.display->print("RECORD"); break;
default:
arcada.display->print("FREEZE"); break;
break;
case 3:
arcada.display->print(" Palette - ");
for(int xPos = 0; xPos < 72; ++xPos) // Display the current heat spectrum colors
arcada.display->drawFastVLine(xPos + 87, (lineNumber - scrollPos) * 12 + MENU_VPOS,
8, colorPal[map(xPos, 0, 71, 0, 255)]);
switch(paletteNum) {
case 1:
arcada.display->print("IRONBOW");
break;
case 2:
arcada.display->print("FIREBOW");
break;
case 3:
arcada.display->setTextColor(0x0000); // Black text for reverse contrast
arcada.display->print("ALARM");
break;
case 4:
arcada.display->print("BLACK HOT");
break;
default:
arcada.display->print("WHITE HOT");
break;
break;
case 4:
arcada.display->print("Temp range - ");
switch(thermRange) {
case 1:
arcada.display->print("STANDARD"); break;
case 2:
arcada.display->print("COOL/WARM"); break;
case 3:
arcada.display->print("WARM/WARMER"); break;
case 4:
arcada.display->print("HOT SPOTS"); break;
case 5:
arcada.display->print("FIRE & ICE"); break;
case 6:
arcada.display->print("FEVER ALERT"); break;
default:
arcada.display->print("AUTO-RANGE"); break;
break;
case 5:
arcada.display->print(" Markers - ");
arcada.display->print(markersOn ? "ON" : "OFF");
break;
case 6:
arcada.display->print(" Image - ");
arcada.display->print(mirrorFlag ? "MIRRORED" : "FORWARD");
break;
case 7:
arcada.display->print("Frame rate - ");
arcada.display->print((float)(1 << frameRate) * 0.5);
arcada.display->print(" FPS");
break;
case 8:
arcada.display->setTextColor(GRAY_33 << 1); // Grayed menu item
arcada.display->print("Emissivity - ");
arcada.display->print(emissivity);
arcada.display->print("%");
break;
case 9:
arcada.display->print(" Smoothing - ");
arcada.display->print(smoothing ? "ON" : "OFF");
break;
case 10:
arcada.display->print(" Backlight - ");
arcada.display->print(screenDim ? "DIM" : "FULL");
break;
case 11:
arcada.display->print("Alarm beep - ");
arcada.display->print(alarmBeep ? "ON" : "MUTE");
break;
default:
arcada.display->print(" Exit menu");
// This is the function that substitutes for GPIO external interrupts
// It will check for A and B button presses at 50Hz
void buttonCatcher(void) {
buttonBits = arcada.readButtons();
clickFlagMenu |= (buttonBits & ARCADA_BUTTONMASK_B) != 0;
clickFlagSelect |= (buttonBits & ARCADA_BUTTONMASK_A) != 0;
Here's what the sketch does. It functions in the same way as the original thermal camera sketch in the guide, but with a different configuration at launch. It starts up with 'Hot Alarm' as the color palette and 4 FPS as the frame rate, and a new color range preset I call 'Fever Alert'. Temperatures above a preset value show up highlighted on the screen in alarm colors of reds and yellows, and trigger a sound effect. It's meant to quickly identify objects or people that are warmer than they ought to be.
The radiant temperature alert threshold is 96.4F, as listed in Comparison of 3 Infrared Thermal Detection Systems and Self-Report for Mass Fever Screening from the CDC. This can be changed if needed, by altering a #define value at the head of the sketch. The default emissivity compensation of the MLX90640 is 0.95, quite close to the common emissivity of human skin, listed as 0.98.
Detected temperatures above the threshold result in a "pew pew" sound effect, so that the operator may look away from the screen while staying alert to high temperatures. (The "pew" sound was the only Arcada compatible audio I could find on short notice. Replace it if you wish.) The sound effect can be muted from the settings menu.
Again, this is not a diagnostic tool, but it might provide a low-cost means of quickly screening people with elevated temperatures. It senses less accurately at longer distances, and any hot object can trigger an alert, like a cup of coffee. If it can aid in improving security or public health, by all means use it freely. I shall check in regularly and answer whatever questions I can. I'm no coding wizard, but this is my best contribution, thanks to Adafruit.
Hallelujah!
Disciple
