Adjustable breadboard power supply doesn't go higher than 5V
by dasmoo on Mon Jul 12, 2010 10:50 pm
I just put together four adjustable breadboard power supply kits, and all four have this issue. Using a multimeter on the Vout and Ground connections on the left, the 3.3V setting is spot on, the 5V setting reads 4.8V, and the adjustable setting ranges from 1.31(+/-0.4)V up to 4.8V. For the project I'm working on I need at least 12V. Could I have made the same mistake soldering all four?
Attached are pictures of one of the power supplies.
dasmoo
Re: Adjustable breadboard power supply doesn't go higher than 5V
by dasmoo on Mon Jul 12, 2010 10:51 pm
Three more shots.
dasmoo
by scott_d on Tue Jul 13, 2010 12:19 am
Well, the obvious first question is what voltage are you feeding into the supply? The output can only be adjusted to about .5V lower than the input.
scott_d
by dasmoo on Tue Jul 13, 2010 1:16 am
Well, there you go. I've got a box of wall warts that are mostly 15-25V, and the one I pull out was just a 5V. Thanks for the sanity reassurance there.
dasmoo
