ST7565 graphics?
ST7565 graphics?
by FuzzyWuzzie on Wed Jul 21, 2010 6:37 pm
Hullo,
I've got the ST7565 lcd up and running nicely (mucho gracias for including the 4050!). Only problem I'm having is getting my own image on the screen (the test program runs perfectly).
How did you create the image bmps? I tried using bmp2glcd, but the picture came out all distorted (parts of it were flipped all over). I also tried creating my own python script to do the task (below), but I couldn't get that to display properly either.
from PIL import Image
def GetPixel(ls, x, y):
   return ls[(y * 128) + x]
def PutPixel(buffer, x, y):
   buffer[x+ (y/8)*128] |= (1 << (7-(y%8)))
im = Image.open("glcd.png")
px = list(im.getdata())
file = open("glcd.c", "w")
buffer = [0]*1024
for y in range(0, 64):
   for x in range(0, 128):
      if GetPixel(px, x, y) == 1:
file.write("static unsigned char __attribute__ ((progmem)) glcd_bmp[] = {\n")
for b in buffer:
   file.write(str(hex(b)) + ",")
file.write("};")
file.close()
Any tips? Thanks!
FuzzyWuzzie
Re: ST7565 graphics?
by FuzzyWuzzie on Wed Jul 21, 2010 6:59 pm
Ok, I realized what my own program was doing - outputting the data in the wrong order. I fixed that up a bit and its working, so if anyone out there wants a tool for converting images into ST7565 graphics, you can use this (or write one yourself..):
#!/usr/bin/env python
import optparse
def ConvertImage(filename, verbose):
   try:
      im = Image.open(filename)
   except:
      print "Error: Failed to open input '" + filename + "'!!"
      return
   width = im.size[0]
   height = im.size[1]
   if width != 128 && height != 64:
      print "Error: Image is not proper dimensions (128x64)!!"
      return
   try:
      file = open(filename + ".c", "w")
   except:
      print "Error: Failed to open output '" + filename + ".c'!!"
      return
   if verbose:
      print "Files opened, parsing input..."
   buffer = [0]*1024
   if verbose:
      print "Input file parsed!"
      print "Writing to output file..."
   file.write("static unsigned char __attribute__ ((progmem)) "+filename+"_bmp[] = {\n")
   for i in range(0, len(buffer)):
      file.write(str(hex(buffer[i])) + ",")
   file.write("};")
   file.close()
   if verbose:
      print "Done!"
      print "Information is stored in '" + filename + ".c'"
def main():
   parser = optparse.OptionParser()
   parser.add_option(   "-v", "--verbose",
                  dest="verbose", default=True,
                  help="Show detailed information about what's going on")
   (options, args) = parser.parse_args()
   if len(args) != 1:
      parser.error("incorrect input file!")
   else:
      ConvertImage(args[0], options.verbose)
if __name__ == '__main__':
   main()
Usage:
Where glcdImage.bmp only has 2 colours and is 128x64 px in size (this doesn't resize or anything). You can use any file format that PIL can convert - jpg, png, gif, bmp, etc.
FuzzyWuzzie
