DHT22 formerly working, now returns errors
by bitnoggin on Sat May 23, 2020 9:16 pm
Hi Guys,
I have a DHT22 connected to a Raspberry Pi 1 running Raspbian (jessie), and python 2.7.9
This is a project which combines the sensor with a relay connected to line voltage, and controlling a dehumidifier.
I have poor records from when I did this project, so I'm sorry I don't have purchase dates, but I'm certain I bought the sensor from Adafruit; I've bought other sensors since, and you are the only ones from whom I buy them. I think I first constructed this project sometime in 2017.
The device as constructed has been running without trouble for at least a couple years. Now, when the controlling script is executed, errors are returned which point to the DHT. The device can still be activated with a manual on or off command, but cannot be triggered by the sensor.
I'm using the following library for the sensor, which I downloaded from Adafruit at the time of purchase:
Adafruit_DHT-1.3.1-py2.7-linux-armv6l.egg
The errors generated are as follows:
File "./dehumidifier.auto", line 69, in <module>
humidity, temperature = dht.read_retry(dht.DHT22, sensorPin)
File "/usr/local/lib/python2.7/dist-packages/Adafruit_DHT-1.3.1-py2.7-linux-armv6l.egg/Adafruit_DHT/common.py", line 90, in read_retry
File "/usr/local/lib/python2.7/dist-packages/Adafruit_DHT-1.3.1-py2.7-linux-armv6l.egg/Adafruit_DHT/common.py", line 76, in read
File "/usr/local/lib/python2.7/dist-packages/Adafruit_DHT-1.3.1-py2.7-linux-armv6l.egg/Adafruit_DHT/common.py", line 59, in get_platform
RuntimeError: Unknown platform.
My first thought was maybe a new version of the driver might be needed, but I can't find a new driver (or even the old one) on your site.
I tend to forget many of the details of these projects, so many months after construction. So I'm hoping I've given enough info you might be able to point me to a relatively simple fix.
Any help will be appreciated. Thank you.
bitnoggin
Re: DHT22 formerly working, now returns errors
by brooney on Mon Jul 27, 2020 6:37 am
not help I am afraid, but similar has happened to me. This morning everything was working fine, restarted the program and the adafruit_DHT no longer works, you have unknown, my shows my raspberry Pi as a beaglebone_black
File "/home/pi/Desktop/planter.py", line 94, in <module>
hum, temp = dht.read(t,pin)
File "/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/common.py", line 80, in read
platform = get_platform()
File "/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/common.py", line 60, in get_platform
from . import Beaglebone_Black
File "/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/Beaglebone_Black.py", line 24, in <module>
from . import Beaglebone_Black_Driver as driver
ImportError: cannot import name 'Beaglebone_Black_Driver' from 'Adafruit_DHT' (/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/__init__.py)
I f i find any answers will post here, if you happened to figure it out let me know ;-)
brooney
by brooney on Mon Jul 27, 2020 7:40 am
if it helps it looks like I ran a apt-get update / upgrade and it changed my CPUinfo to show that I have Hardware : BCM2711 I kinda hotwired platform_get() to treat that as a raspberry pi 3 and now it is working.... (I know this is a poor answer and poor solution but it fixed it.)
brooney
by Radnor302 on Thu Jul 30, 2020 5:50 pm
brooney wrote:if it helps it looks like I ran a apt-get update / upgrade and it changed my CPUinfo to show that I have Hardware : BCM2711 I kinda hotwired platform_get() to treat that as a raspberry pi 3 and now it is working.... (I know this is a poor answer and poor solution but it fixed it.)
How to "hotwire" platform_get()? And with what? I'm in same boat
Found it and patched it. For those looking for it,
/usr/local/lib/p...3/dist.../ada.../platform_detect.py
Radnor302
by osoblanco84 on Thu Aug 13, 2020 12:51 am
What did you do im trying to fix it myself but i cant edit the lib file and not sure what yall are changing.
osoblanco84
