Adafruit Joy Bonnet for Raspberry Pi Joystick not working.
by absolutspl on Tue Aug 04, 2020 10:46 am
Adafruit Joy Bonnet for Raspberry Pi Order# 2336654-0263643608
installed "sudo bash joy-bonnet.sh" (see info below)
ABXY, select, start,Player 1 and 2 works Joystick can not be configured.
I read this: viewtopic.php?f=19&p=617817
Info:
Retro-pie version: 4.6 on Pi zero
pi@retropie:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
absolutspl
Re: Adafruit Joy Bonnet for Raspberry Pi Joystick not workin
by mikeysklar on Tue Aug 04, 2020 4:40 pm
Hi absolutspl,
Could you share a photo of the underside of the Pi GPIO header pins if you had soldered them yourself.
Also the contents of /boot/joyBonnet.py
It should look something like this:
mikeysklar
by absolutspl on Wed Aug 05, 2020 6:26 am
It was used on a Raspberry pi zero w/header & I also tried it on a Pi 3 B+.
I had loaded a fresh Retropi OS 4.6 on each system.
I ran :
curl https://raw.githubusercontent.com/adafr ... -bonnet.sh >joy-bonnet.sh
Here's the file you asked for.
absolutspl
by mikeysklar on Wed Aug 05, 2020 10:58 am
Hi absolutpl,
I think I found something. Let me know what you see here.
cat /opt/retropie/configs/all/runcommand.cfg
Is disable_joystick="1"
If so you can change it here:
"Launch Menu Joystick Control" to "Enabled".
mikeysklar
by absolutspl on Wed Aug 05, 2020 11:05 am
pi@retropie:~ $ cat /opt/retropie/configs/all/runcommand.cfg
use_art = "0"
disable_joystick = "0"
governor = "performance"
disable_menu = "0"
image_delay = "2"
absolutspl
by absolutspl on Fri Aug 07, 2020 6:26 am
mikeysklar wrote:Hi absolutpl,
That was already disabled.
absolutspl
