No Humidity Reading from AHT20
by djotaku on Wed Aug 05, 2020 9:11 pm
I purchased the AHT20 breakout board: https://www.adafruit.com/product/4566
To start off, I connected it to an Onion Omega2+ via their Qwiic Exp board and STEMMA QT connector. I used the code that can be found here: https://gist.github.com/djotaku/d1a0613 ... acf1107955 -> this is the same code as https://learn.adafruit.com/adafruit-aht ... cuitpython, but with f-strings. (However, it's important to note that when I used EXACTLY the code from that site - as in no f-strings - it did not work)
I get a temperature reading, but not a humidity reading.
I went on the Adafruit discord to see if others could offer some help. After speaking on there, I tried the following:
  • Tried touching the sensor with my finger. In my experience, doing this with the enviro phat or Arduino ENV shield would cause the reading to go up from the humidity in my skin. This did not work. Also, the Clue Adabox Demo was reporting a 30% humidity in my room.
  • Next I tried a different Stemma/Qwiic port on the Onion Omega2+ in case the port I was using was bad. This still resulted in a temperature reading, but not Humidity.
  • Next I tried the OTHER stemma/Qwiic port on the AHT20 breakout. Same result again.
  • Next I tried a different cable in case the Stemma/Qwiic cable I was using was bad. Same result. Also, since the stemma is I2C, I imagine if I can get temp, everything is OK on the connection?
  • Then I was advised on the Adafruit Discord to try a different device in case it's the Onion Omega2+'s fault. So I tried my brand new Adafruit Clue from the Adabox 15. I first tried in CircuitPython as that is easy to do with that board. Once again, temperature, but not humidity.
  • Finally, I was asked to program it via the Arduino IDE. I did that, using the example code (I will list below so you can be confident in what I did). Once again, it did not work.
At this point, I was advised to post on this forum.
Appendices:
Code from Arduino programming:
#include <Adafruit_AHTX0.h>
Adafruit_AHTX0 aht;
  Serial.begin(115200);
  Serial.println("Adafruit AHT10/AHT20 demo!");
  if (! aht.begin()) {
    Serial.println("Could not find AHT? Check wiring");
    while (1) delay(10);
  Serial.println("AHT10 or AHT20 found");
  sensors_event_t humidity, temp;
  aht.getEvent(&humidity, &temp);// populate temp and humidity objects with fresh data
  Serial.print("Temperature: "); Serial.print(temp.temperature); Serial.println(" degrees C");
  Serial.print("Humidity: "); Serial.print(humidity.relative_humidity); Serial.println("% rH");
  delay(500);
Output from serial monitor in Arduino mode:
21:00:16.352 -> Temperature: 24.31 degrees C
21:00:16.352 -> Humidity: 0.00% rH
21:00:16.885 -> Temperature: 24.29 degrees C
21:00:16.885 -> Humidity: 0.00% rH
21:00:17.446 -> Temperature: 24.30 degrees C
21:00:17.446 -> Humidity: 0.00% rH
21:00:18.009 -> Temperature: 24.30 degrees C
21:00:18.009 -> Humidity: 0.00% rH
and so on and so forth
djotaku
Re: No Humidity Reading from AHT20
by adafruit_support_carter on Thu Aug 06, 2020 12:36 pm
Let's continue to use the CLUE for testing.
How did you connect the CLUE and AHT20 together?
by djotaku on Thu Aug 06, 2020 6:28 pm
I used the Stemma/Qwiik connector between the board and the Clue
djotaku
by adafruit_support_carter on Thu Aug 06, 2020 6:59 pm
Excellent. Nice and easy.
OK, load CircuitPython back on to the CLUE and try running through these commands via the REPL and see what you get:
Adafruit CircuitPython 5.3.1 on 2020-07-13; Adafruit CLUE nRF52840 Express with nRF52840
>>> import board
>>> i2c = board.I2C()
>>> i2c.try_lock()
True
>>> i2c.scan()
[28, 56, 57, 68, 106, 119]
>>> i2c.unlock()
>>> import adafruit_ahtx0
>>> sensor = adafruit_ahtx0.AHTx0(board.I2C())
>>> sensor.temperature
21.7892
>>> sensor.relative_humidity
50.025
by djotaku on Thu Aug 06, 2020 8:37 pm
OK, the first difference I got was on the scan.
>>> import board
>>> i2c = board.I2C()
>>> i2c.try_lock()
True
>>> i2c.scan()
[8, 28, 56, 57, 68, 106, 119]
Then again a rel_hum of 0.0:
>>> i2c.unlock()
sensor.temperature
24.2733
0.0
djotaku
by adafruit_support_carter on Thu Aug 06, 2020 8:46 pm
Interesting. Run the scan again a couple of times. Does that address of 8 keep showing up?
by djotaku on Thu Aug 06, 2020 8:54 pm
It goes away after the first scan:
>>> i2c.try_lock()
True
>>> i2c.scan()
>>> i2c.scan()
>>> i2c.scan()
>>> i2c.scan()
>>> i2c.scan()
djotaku
by adafruit_support_carter on Thu Aug 06, 2020 9:00 pm
OK, thanks. I think that's unrelated to the humidity issue. Let's just replace your sensor.
Send an email to support@adafruit.com with a link to this thread and your order number and they can send you a replacement AHT20 sensor breakout board.
by djotaku on Thu Aug 06, 2020 9:22 pm
OK. Thank you for your help. I have a new arsenal for debugging for the future.
djotaku
