HDMI 7" 800x480 Display Backpack - With Touchscreen - Touchs
by Pmmoore2 on Sat Aug 08, 2020 5:45 pm
Hi I recently purchased HDMI 7" 800x480 Display Backpack - With Touchscreen: https://www.adafruit.com/product/2407
The display works. However, the touchscreen functionality does not. I've tried it with both my Rasp Pi 4 and a Windows 10 laptop. When I run the ARconfig tool provided by Microchip I get this error message: 2:35:34 PM Error: Could not change mode to Mouse. Verify the AR1100 is properly attached
Any attempt to change Communication mode, verify communications or use the ARconfig tool at all gives me an error message. I currently have the screen plugged into my laptop via HDMI and USB.
The red light on the bottom indicating touch does blink rapidly when I touch the screen. However, I can't interact with the screen.
Please assist. Thank you!
Pmmoore2
Re: HDMI 7" 800x480 Display Backpack - With Touchscreen - To
by adafruit_support_carter on Mon Aug 10, 2020 1:16 pm
On the Pi, after plugging in the USB cable, run this command:
dmesg | tail -20
and post the output here.
That will hopefully contain some informative messages about what is happening on the Pi when the board is plugged in.
by Pmmoore2 on Sat Aug 15, 2020 1:33 pm
Hi! I apologize for the delay in responding. Thank you for your help.
Here's the output:
pi@raspberrypi:~ $ dmesg | tail -20
[    8.168569] bcmgenet fd580000.genet eth0: Link is Down
[   11.207613] fuse init (API version 7.27)
[   12.712608] Bluetooth: Core ver 2.22
[   12.712648] NET: Registered protocol family 31
[   12.712653] Bluetooth: HCI device and connection manager initialized
[   12.712664] Bluetooth: HCI socket layer initialized
[   12.712672] Bluetooth: L2CAP socket layer initialized
[   12.712695] Bluetooth: SCO socket layer initialized
[   12.721891] Bluetooth: HCI UART driver ver 2.3
[   12.721901] Bluetooth: HCI UART protocol H4 registered
[   12.721954] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   12.722077] Bluetooth: HCI UART protocol Broadcom registered
[   13.026168] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   13.026174] Bluetooth: BNEP filters: protocol multicast
[   13.026184] Bluetooth: BNEP socket layer initialized
[   13.068364] Bluetooth: RFCOMM TTY layer initialized
[   13.068384] Bluetooth: RFCOMM socket layer initialized
[   13.068401] Bluetooth: RFCOMM ver 1.11
[   18.562311] logitech-hidpp-device 0003:046D:4051.0004: HID++ 4.5 device connected.
[   42.949706] logitech-hidpp-device 0003:046D:200A.0005: HID++ 1.0 device connected.
Pmmoore2
by adafruit_support_carter on Mon Aug 17, 2020 12:15 pm
Thanks. Looks like maybe it's still in raw HID mode. So, going back to what you got here:
What happens if you try the "Verify Communication" button?
https://learn.adafruit.com/ar1100-resis ... 1081714-23
by Pmmoore2 on Tue Aug 18, 2020 9:28 pm
Hi! Below is what i got after clicking the Verify Communications button a few times. I also tried to switch to Mouse and Verify Communications again.
It's acting like it can't talk to the monitor at all. Monitor is hooked up to laptop via HDMI and USB. Monitor working, just no touch function.
6:08:35 PM  Welcome to the Microchip AR Configuration Utility version 2.20
6:08:36 PM  Found Tub.dll - Ver: 1.5.0.0
6:08:36 PM  USB AR1100 could not be found.
Please check your connections.
6:08:36 PM  Welcome to the Microchip AR Configuration Utility version 2.20
6:08:47 PM  Checking Communications . . .
6:08:47 PM  Cannot perform communications check in this mode.  Reconfigure AR1100 as an HID-Generic device first.
6:09:09 PM  Found Tub.dll - Ver: 1.5.0.0
6:09:09 PM  Error: Could not change mode to HID.  Verify the AR1100 is properly attached
6:09:12 PM  Found Tub.dll - Ver: 1.5.0.0
6:09:12 PM  Error: Could not change mode to Digitizer.  Verify the AR1100 is properly attached
6:09:16 PM  Looping through existing Comm ports looking for AR1100 . . .
6:09:16 PM  Error: could not open com port COM8i at 9600 baud.
6:09:22 PM  Found Tub.dll - Ver: 1.5.0.0
6:09:22 PM  Error: Could not change mode to Mouse.  Verify the AR1100 is properly attached
6:10:00 PM  Found Tub.dll - Ver: 1.5.0.0
6:10:00 PM  Error: Could not change mode to Mouse.  Verify the AR1100 is properly attached
6:10:39 PM  Found Tub.dll - Ver: 1.5.0.0
6:10:39 PM  Error: Could not change mode to Mouse.  Verify the AR1100 is properly attached
6:10:41 PM  Found Tub.dll - Ver: 1.5.0.0
6:10:41 PM  Error: Could not change mode to Mouse.  Verify the AR1100 is properly attached
Pmmoore2
by adafruit2 on Wed Aug 19, 2020 11:46 am
ok open the Device Manager in windows. when you unplug/plug in the USB cable, does it 'refresh' and show an HID device appear/disappear
adafruit2
Site Admin
by Pmmoore2 on Wed Aug 19, 2020 9:30 pm
It does show up when I plug in the USB - but not under HID. It has it's own category as UPDD Device. Screenshot below.
I did install the UPDD driver_06_00_617 when I was first trying to sort out the problem myself, before contacting you.
Pmmoore2
by adafruit2 on Thu Aug 20, 2020 2:22 pm
that is weird, because obviously the device is there. hmm, i really odnt know why its doing that - lets replace it. email support@adafruit for a new display
adafruit2
Site Admin
by Pmmoore2 on Sat Aug 22, 2020 1:37 pm
It is weird! I played around with this thing for a while before even contacting all of you. Thank you for your help and support! I'll email.
Pmmoore2
by Pmmoore2 on Tue Sep 08, 2020 7:42 pm
The new display works perfectly out of the box. Thank you all for your help!
Pmmoore2
